18’s on P400 using spacers?
The following 3 users liked this post by GavinC:
https://www.autorimshop.com/18-oem-w...RoCQmMQAvD_BwE
I read a Facebook post where a guy fitted LR3 wheels (I think I found them - linked below) on his P400 using what looks like 20-30mm spacers, unless the offset on those requires larger spacers which wouldn’t be immediately obvious. His vehicle certainly didn’t look like the image above. I wonder if anyone else has tried.
EchorecT7E (07-13-2023)
I was thinking of answering along the same lines. Your pic killed it, tho.
GavinC (07-13-2023)
and no way is someone fitting 30mm spacers without a whole lots of work to extend and install longer wheel studs. There is a thread somewhere in here on someone doing just that. looks like the whole wheel assembly needs to come apart. Yes i know you can use a spacer with additional outbound lugs but if you are using your 18's for serious offroad fun two sets of lugs per wheel is nothing more than additional failure points.
