275/70 r18s?
275/70 r18s?
I have already blown 2 of the OEM 'offroad' tires. Do not recommend!! So the defender is now sitting dead in the driveway. I need some real tires and want to go slightly bigger without requiring rods.
Anyone know if 275/70 r18s will fit? It is 33 vs 32 inches, 10 vs 10.8 inches wide. I'm worried about rubbing but thought Lucky8 fit 33x12.5 underneath but assuming with spacers.
I want KM3s. Have run KM2s on my P38 for many years. The KO2s on my LR3 cup horribly.
I also saw the post about the spacers someone posted not working with steel wheels. I'm sure i can find some that will.
I need to order tires asap!
I run 255/85 r16s on my P38 for years and loved those tires. Good manners and not noisy. I have the Generals on my D90 and they have performed well. Got them in a swap.
I went with Yoko Geolandar A/T GO15. I found 10-ply 275/65R18 which we're only about $210/ea. I had them before and found them great in all conditions, especially the long Northern Michigan winters.
Now, finding wheels that fit well, is a different story. I had them mounted on some 18" P38 wheels and there just is not enough clearance around the back calipers.
I was looking at General Tires too, but their newish "hybrid" ATX model, sized LT265/70R18 E-load range. I like the speed rating of those (S, kind of rare for LT tires with such specs), and they aren't as aggressive as the X3s, which should probably make them a bit quieter and more livable on pavement, although they surely wouldn't be as good in mud - then again, there's not a lot of mud here in SoCal. They are 3-peak mountain snowflake rated.
Another excellent tire I have had good experience with, again in the "hybrid", more aggressive than ATs but not as uncompromising as MTs, category, is the Nitto Ridge Grappler. I had them on my LR4 and they were virtually indestructible, and so quiet compared to even Nitto's Terra Grapplers G2. They also have a LT265/70R18 size available. They are not snow rated, kind of expensive and with only a Q speed rating, however.
