Activating ACC and other features via Pathfinder App
#21
I was able to get ACC activated using the Autosvs JET PRO using the 3-day demo license. I also enabled dynamic mode and a couple other features.
I used this cable ordered from Amazon. Bluechok Enet OBD2 RJ45 Cable,Ethernet 6.6ft/2M Cable RJ45 ethernet Connector Tools to OBDII Interface Cable Car Diagnostic Coding F-Series for BMW Coding Diagnostics https://a.co/d/ckpdKYe
Originally I used a cable that I had for an F series BMW coding, but that gave me errors. I switched to this cable and also switched laptops and ensured that the car battery was well charged. One or a combination of those things cleared up the problem.
Thanks to Gary at Autosvs for his support. Also thanks to those on this forum for bringing this to my attention.
The following 4 users liked this post by verrilli:
#22
I've got the GAP tool and the idiot proof instructions for its activations were very useful. ACC is the last nut to crack. Seems like you and other smart cookies have cracked it. Well done.
#23
Is there a step by step walkthrough of the process anywhere? One that caters for the dumb-as a-box-of-rocks contingent like myself a close friend of mine.
https://www.defender2.net/forum/topic90062.html
#24
Not quite step by step, but the following thread brings together practical experiences of using the JET Pro tool:
I need it real slow and basic. Do A, then B then C, D etc ..... then laugh as you cruise off into the sunset.
73matt (11-22-2023)
#25
Here are the steps I took to activate ACC on my 2022 Defender 110 (as best I can remember)
- order the cable from Amazon. wait for it to come
- Order the software. Software. Select the Car Owner 1-VIN
- You should get an email confirming order. Check spam folder if you don’t see it
- Use the help bubble on the web site to connect to Gary on WhatsApp and request temp login code
- disable virus detector on your laptop I. Windows security settings
- download the JET Pro Installer using the link on the orders page
- unzip the folder
- run the installer using windows run command. You may need to run as administrator
- Copy the install key from the file in the unzipped folder
- paste it into the pop up window
- press install. jet pro icon should be on your desktop
- add a virus detector exclusion for the jet pro exe file in window security settings
- Start the jet pro software
- enter the login code given by Gary. You now have 72 hours to complete the task
- You should see the menus.
- plug in OBD cable and plug in Ethernet to laptop
- press ign button on car but don’t put foot on brake
- Press connect. You should see screen like this with green circle
Screenshot 1 - check that the battery voltage in upper right is green. If not, disconnect and run engine for a while to charge battery
- Go to CCF Brushing menu
Screenshot 2 - Press Read CCF
- Press script list. You’ll see screen like this
Screenshot 3 - select 17 for ACC. You may need 18 if yours is prior to MY 2022
- press OK. The script should run
- press exit
- Press write current data. The car will make lots of flashes and noises. Check that there are no write errors
- go to Main menu
- select CCF Memory
- select first menu item,DADC
- Select second menu item, IGM
- Go to DTC menu, select read DTC, then Clear DTC
- when complete, go to main menu and disconnect
- unplug cable
- turn off ignition
- lock car for 10 minutes
The following 5 users liked this post by verrilli:
ckamps (12-04-2023),
Defendit.. (11-24-2023),
GavinC (11-23-2023),
Iceman153 (11-23-2023),
WMN (11-23-2023)
#26
Wow @verrilli
Thanks a bunch. This is incredible.
If you ever find yourself in my neck of the woods, beers are on me.
Much appreciated for going to such trouble.
I wonder is this the type of solution the good folks at GAP Diagnostics have been working on getting to gel with their IID tool.
verrilli (11-23-2023)
#29
#30
I did mine a few weeks ago and figured it out with the help of a user on the defender UK forum. It’s not the easiest software to use but is also difficult to screw things up.
they allegedly have auto parking working on some vehicles but I havent heard of anyone successfully activating it with this tool. I would avoid that option if having a not-working app on your PIVI would bother you (mine crashes when opened).
