Adaptive cruise not very good
Anyone else’s adaptive cruise not very good?
1. Always making micro adjustments to speed that makes you shift forward and backward subtley 2. Takes a little too long to start from a stop when the car in front starts moving 3. Doesn’t slow down sufficiently when traffic stops ahead and you’re going fast, so emergency braking alert comes on. I bought this car for road trips but the ACC’s lack of smoothness and smarts ruins it for this use case. Hoping for a SW update to improve this but I’m assuming since this car has been out 4 years already it’s not coming . . . |
Mine behaves the same way. It's rubbish.
I'm not a huge fan either. I think it's "OK". Certainly not great and could be improved.
I live in a hilly and windy area of highways and it’s not good on that, but once I leave and get more into open and straightish highways with sweeping long turns I’ve found it to be good.
elevation changes and sharper turns it definitely struggles with. OP, what kind of roads are you on using ACC? |
I think it's terrific on the highway but average at best in town. To be fair, it's the only car with ACC I have ever driven.
Originally Posted by NativeTexan
(Post 888821)
Originally Posted by Racer20
(Post 888813)
1. Always making micro adjustments to speed that makes you shift forward and backward subtley 2. Takes a little too long to start from a stop when the car in front starts moving 3. Doesn’t slow down sufficiently when traffic stops ahead and you’re going fast, so emergency braking alert comes on. I bought this car for road trips but the ACC’s lack of smoothness and smarts ruins it for this use case. Hoping for a SW update to improve this but I’m assuming since this car has been out 4 years already it’s not coming . . . 2. I drive in LA traffic and use the ACC every day, but I have adopted a style where, if coming to a stop, I apply the brake, restart manually with throttle, and then re-engage once moving. It's not Ideal, but it works well for me. 3. yep! Get that. It's not the best. :-) |
| All times are GMT -5. The time now is 12:30 AM. |
