Anyone get the 4.1.4 update?
#41
The only thing I've noticed (mine expired two weeks ago) is the weather app no longer works. It didn't disappear though. It just prompts me to renew. Everything else, traffic updates, search for POI, etc. works. Everything. I never used alexa or spotify, so I don't know about that.
#42
A lot of times any errors just means you need to log into In-Control in the vehicle and on the app. (just open the app and lock the doors usually works)
Seems like when these updates come through I lose connection to at least Spotify, sometimes the weather app. At some point I'll get an error that says I need to re-log into the vehicle and/or in-control. This last update I could open Spotify but couldn't navigate the app. After a week of no use it decided to finally tell me to log back in. JLR's IT deployment team could use some Agile training.
#43
#45
#46
I can confirm seeing the same things in 4.1.4 update. Actively using Apple Maps to navigate, CarPlay upcoming turn notifications popup in my dash then disappear after the turn - reverting to my previous digital dash screen setting. I don't find it particularly objectionable but I appreciate your point. I'm not aware of any method to turning it off but haven't made any serious effort to look. I wonder if muting the turn by turn spoken instructions *might* disable the prompt in the instrument cluster? I haven't tried
#47
#48
side of the steering wheel,then select "info panel"
Scroll down and change it from "map" to something else such as "media" or "speedometer"
#49
Unfortunately this does not work with the new update. I usually have the info panel set to Media and the directions still show up before a turn.
#50
Okay.
l have the latest update and it worked for me. However l have the basic dashboard with only the center part display digital.
The speedometer and RPM are traditional analogue gauges.
lf you have the full digital dashboard it may be different.
Note you can't un-check the "map" you have to actually select something else to get rid of it.
