Check engine light
Back
I posted last month my def 110 started shifting in a very jerky fashion and the check engine light came on. I managed to get it to my dealer and i posted their resolution having to do with fuel pressure.
Anyway, today, my check engine light came on and the symptoms returned, albeit not so drastically. I have managed to get home and am contemplating my next move. I will call the dealer tomorrow but i am not optimistic about an early appt or a loaner. Oh well.
Here is the text of the work done:
CUSTOMER STATES THE CHECK ENGINE LIGHT CAME ON. THEY WERE DRIVING IT AND THE VEHICLE STARTED CHUGGING AND LOST POWER. CUSTOMER STATES THE VEHICLE WILL MAINTAIN ELECTRICAL POWER BUT WILL NOT GO WHEN STEPPING ON THE GAS PEDAL. IF YOU TRY TO RESTART IT WILL CRANK BUT NOT FIRE. THEN WHEN LETTING IT SIT AND EVERYTHING SHUTS OFF. HE WILL RESTART AND EVERYTHING IS WORKING AGAIN BUT THE CHECK ENGINE LIGHT STAYS ON. PLEASE ADVISE.
CONNECTED PATHFINDER AND RETRIEVED FAULT P1338·38•FUEL PUMP DRIVER MODULE COMMUNICATION CIRCUIT-SIGNAL FREQUENCY INCORRECT. INSPECTED POSSIBLE CAUSES-CHECKED POWER AND GROUND AT FUEL PUMP MODULE DRIVER. VERIFIED CONNECTOR WAS IN GOOD CONDITION. USING PICOSCOP, ACCESSED PCM CONNECTOR FOR FUEL PUMP MODULE SIGNAL WIRE, VERIFIED IRRATIC SIGNAL. TOOK THE SAME MEASUREMENT AT FUEL PUMP MODULE DRIVER IN RIGHT REAR WHEEL TRIM. VERIFIED SAME ERRATIC SIGNAL. ORDERED AND INSTALLED NEW PCM. ALSO, PERFORMED SIGNAL WIRE OVERLAY FROM PCM CONNECTOR C1E109B-71 TO C4E515A·7 ON THE FUEL PUMP MODULE DRIVER-FROM PCM, UNDER WINDSHIELD COWL, DOWN THE RIGHT FRONT SHOCK TOWER, BEHIND RIGHT FRONT WHEEL LINER, RUN NEXT TO AIR SUSPENSION LINES TO THE RIGHT REAR WHEEL LINER. AFTER OVERLAY WAS COMPLETED, ATTEMPTED TO
PROGRAM PCM. TOPIX CLOUD GAVE NO APPLICATION TO PROGRAM PCM. STARTED TA 3407855 AND REQUESTED CODE TO USE PATHFINDER. DOWNLOADED PATCH FILE, INPUT CODE PROVIDED BY TA, ACCESSED PATHFINDER AND SUCCESSFULLY PROGRAMMED PCM. TEST DROVE VEHICLE AND VERIFIED NO FURTHER ISSUES.
I hope the month long wait will have finally fixed the issue (whatever it is.... all this stuff is way above my understanding).
Cheers
Chief65 (06-24-2022)
Seems the soft/firm ware on the Engine Control Unit (ECU) which tells the fuel pump module to tell the fuel pump to deliver fuel somehow became corrupted, necessitating reloading the ECU logic. Uggh! Glad they solved it (hopefully!).
This new world of software doing everything -- relating to an electronic module controller -- in order for the module controller to make anything happen electrically or mechanically in the vehicle is so new. A different world. A lot to digest (for me at least).
Enjoy !
Enjoy !
GrouseK9 (06-24-2022)
You describe it exactly how mine behaves when it stalls like that. p300 also btw. The only time for me the check engine light stayed on after the incident was the first time it happened, and then I brought it in immediately where they said they updated code on the module. After that it has continued to stall but it's still very intermittently, maybe six times in the 11-12 months that I've owned it. It has not stalled yet when pulling out into a heavy traffic situation (fortunately) so I haven't been at serious risk of being rear-ended but that's more luck than anything else. My first scheduled maintenance was last week and by chance it stalled the day before that at 5:30pm. I mentioned it to the service manager, I said it's still stalling as recently as yesterday so please check for a code from yesterday. He said they checked and no code was logged.
Like I said I love the vehicle in a lot of ways but I'm pretty sure when I trade it later this year I won't shed many tears. Between the seats being problematic, loose backrests and clicking noises from the track areas then this stalling issue, I feel like I'm getting played for over a grand per month and I can get played for a lot less than that.
