Check Engine when Towing?
I get a check engine light (emissions) that shows up every time I tow my 22' Airstream Bambi. It's well within towing spec - and the check engine light disappears after I've disconnected and drive without the trailer. Happens every time I tow ... has anyone else seen this?
I have been towing for 10K miles or so on my 2022 P300 110 and have had no such issue. Assuming your gas cap is tight in either case, and just guessing, it sounds like either a wiring problem in the vehicle, Including in a control module, or a sensor issue in the emissions. Or maybe it has the PCV valve leak ?
It has thrown an error code, so your dealer has something to go on. They should be able to trace it, hopefully.
Good luck !!
Good luck !!
GrouseK9 (07-15-2022)
