Enhanced engine sound de activation
i remember a day when the forums were a place to help each other out.
if you don’t know the answer just keep quiet
you have to find a tuner than can deactivate the engine noise. Same tuners that activate say adaptive cruise control and other features not added as options. it is an option.
didn’t read into where you are located but there are several in the UK
companies like below
https://www.jlractive.com
Problematic of these cars are terrible plastic quality and workshop processing of lot of details for car in such price category... Cause that I called it UK crap.
there are technically two related audio enhancements in the vehicle.
ANC or active noise cancelation
Fake engine noise- there is a technical term but fake engine noise is basically what is is
both of these cause havoc if you are planning to upgrade your car audio. This is the reason i looked into.
there is no module that you can just unplug for the enhance engine noise. it’s built into the car audio digital sound processor which you need to code out
I just check that in this car it sounds only from front channels / speakers and only between 1000-1200 rpm range, does not matter how fast do you drive, it works also on neutral while standing. It is kind of 40-75 hz signal like from frequency generator. If you have got only oem speakers it is not much audible, but with better amp, good front speakers and sub, it start to be a big problem. I just fix it only by this way for now : source signal for subwoofer I use only from rear channels which are absolutely clean and front speakers are with highpass filtration from about 75-85hz. But it will be best solution to absolutely deactivate this weird function.
https://auto-hifi.sk/auto-hifi-insta...fender-t300-2/
R-dubb (02-23-2024)
did you find a solution for this?
I do have the exact same issue on ma RR Sport 2022, after a contractor upgraded all mu my speakers, puts a DST and subwoofer in the car. He is telling me that there is nothing to do with it... really embarassing noise.... any hints from your side?
thank you
Hi Elektron
thank you
thank you
It’s is a HELIX V EIGHT DSP MK2 (Audiotec Fischer)
Noting that the fake engine noise is not there anymore IF I unplug the subwoofer.
it also disappear is one window is slightly open…
rest of the set up is :
- AMP HELIX M ONE X , for the SW: first took the signal from the DSP (but noise was there) then sourced it straight from the 400W main amp (noise still there)
- HELIX K10SE.2 Subwoofer
- new front and rear speakers (4 Tweeters and 4 MidWoofers)
