Extended Fender Flares US Spec
I'll spend some time on it this weekend. Would love to be able to modify these EU flares to fit these sidemarkers... here is the quote from Vulkan when I asked:
"Regarding the reflectors, we are still developing a solution that is 100% compliant with the regulations - our supplied reflectors are just reflectors (no lamps) and are all orange. It is possible to reuse the existing lamp reflectors, but you will need to cut a larger hole and adapt the existing wiring for the lamp. If you are able to use the arches without the reflectors for now, that would be our recommendation."
do you find the smaller mud flap does it’s purpose? i have the classics on my other defender and they do an amazing job. prob more to prevent cars behind me getting splashed
Part of the mud flap is doing nothing (left side in photo), and the other side doesn’t cover the tire (right side in photo).
No big deal and better than nothing.
The following 3 users liked this post by mikelr:
kost dealers won’t even notice it’s not there. they are oem fenders so unless something looks off i doubt they will notice
yeah you just unplug them and push it back into the body. i wrapped the connector is a bunch of tape to try to make it waterproof. no errors or check engine lights
when are you planning to install your vulcan pieces. i like that they are painted and just wanting to make sure they fit properly
I picked up a set of already gloss painted wheel arches from Vulkan.. they come as EU spec with no side markers.. They do have a little cut out to put reflectors in but doesn't think the actual NA side markers will work.
Just curious what you did with the lights when you put yours on? Did you just tuck the bulb into the fender area?
Do you have a picture?
