Extreme wind noise : 2021 defender 110
I just purchased a 2021 110 SE p400 with 7700 mi on it.
Today ,was the fourth day that I've had it on the interstate and the noise was unbearable.
A few days ago, I had a constant wind noise in my ear coming from the passenger driver side window. If I turn the radio volume up to about 30 it drowned it out but if I turn the volume down and tried to make a phone call ,all I could hear was the wind in my ear as if I was in a jeep with no top on it. Today ,the same noise except for now there's a whistling coming from the window as well. I contacted the dealer and I was advised they could see me in two weeks .. I am hoping some of you guys have a solution to this.
Thk you
UPDATE 3/27/22
I believe I found the issue. Appears the window is loose as well as the door molding.
Is this the pillar problem others have discussed?
I made a video but I'm unsure if it will upload...androids are not the best at sharing videos etc.
https://photos.google.com/share/AF1Q...NJUmVWNE90dDVB
Thk you
UPDATE 3/27/22
1. Welcome to a Defender. Read a lot of threads on this forum and become a student of the Advanced Search. There's a lot of good tips in here, don't use the normal search.
2. If you have aftermarket tires, that makes it worse. Roof rack, ditto.
3. Specifically re: window noise, it will help to locate it. Lots of #1's (Search) to help. If it's the A-Pillar, known problem - easy cures (new A-pillar or felt). If it's the windows, ditto (silicon lube the rubber). If you get more specific where, you'll get more tips. Maybe have someone else drive and take a short ride in back until you can isolate it.
4. Good luck with the Dealer. Bring Chocolate Chip cookies per "Click & Clack".
Final Tip: Post "Defender ****" (Pics of your Defender getting dirty or freshly clean or in dark lighting or basically any other pic really) and you'll get more responses!
mopadzi (03-25-2022)
One other thing to check, that took me a while to figure out, is loose weather molding on the door seal. Mine is specifically the rear passenger door. It comes loose and then gets caught in the door when closed quickly. I have to realign it and then softly close the door for the seal to be semi decent. I've got about 7500mi on mine and still havent been bothered to take it in yet. It is annoying and extremely loud if I dont fix it, or a passenger doesnt know about it.
Hopefully that's what's going on with mine . It's iso loud, there's no way a passenger could sit behind me
GrouseK9 (03-24-2022)
