Fog lamp automatic behavior
Old 02-17-2024 | 10:04 PM
Pangea123's Avatar
Default Fog lamp automatic behavior
I have a 23 110 V8. I have noticed that the front fog lamps illuminate automatically if you signal a turn after dark for cornering.
Also noticed the rear fog lamps wont turn on at all, unless the fronts are already illuminated
I am interested in using the fog lamp switch to activate a light bar. I’m thinking given the above the rear lamp switch is my best bet
does anyone know why this might not work? It doesn’t have similar behaviors where it turns itself on and off based on a turn signal right?
Another related question: any way to turn off the auto cornering lamps or make the rear fogs turn on independently of the fronts? Maybe in the GAP tool?
thanks for your wisdom
Old 02-18-2024 | 08:48 AM
Ratledge's Avatar
GAP iid tool can set the "CL" off instead of active when fogs aren't on. Cornering Lamps aren't mentioned anywhere because you normally don't have any control.
I hadn't noticed that the rear fogs are switched by requiring front fogs on. Don't know, but it's not something I would have looked for while in GAP.
Mine is a MY23.5 D90S (4 cylinder "P300").
Pangea123 (02-21-2024)
Old 02-20-2024 | 03:46 PM
krisgnb's Avatar
Actually, i noticed the other day that the corresponding fog light turn off when the signal light is activated when my wife was following me .. Weird i thought ...
Anybody else notice this ?
Old 02-20-2024 | 04:53 PM
Yulongtd6's Avatar
I just noticed this the other day in the same situation.
krisgnb (02-20-2024)
MichiganRover
LR4
02-03-2021 06:58 AM
emille26
05-04-2020 12:51 PM
Xjsport95
07-24-2019 08:56 PM
rduff
03-28-2008 08:55 PM
Benhamtroll
12-05-2005 04:28 AM
Quick Reply: Fog lamp automatic behavior
