Front end protection question
OK, fairly certain my new build came with neither of the following that were to have been installed...but I'm realizing I don't even know what each of these things is/looks like.
Thanks,
Brice
- Front Undershield
- Front Expedition Protection System (this)
Thanks,
Brice
SilverSFR (01-17-2023)
Thanks,
Brice
- Front Undershield
Thanks,
Brice
The FEPS seems like some dealer upsell but if I had to guess its the bit of extended black plastic on the front on the picture in your link. I guess, based on the description, when you run someone over it gives you that buffer so they don't hit your bonnet right away(?).
Here is a video prom Powerful UK which will show
the installation of the front undersheld.
Picked up my 110 P300 S Saturday which did not have the front under shield which I had ordered. Next link shows an aftermarket front undershield
which is likely the way I will go.
Thanks,
Brice
- Front Undershield
Thanks,
Brice
I have the aftermarket one on order, expected to arrive tomorrow. In PowerfulUK's installation video they show cutting away the panel behind the under shield, this would remove mounting points for the original cover which I prefer not to do. My question is, can it be installed without cutting away the panel? I read a comment that this may be possible.
Matt
this_account_is_mt (10-24-2022)
That said, the original plastic cover hiding the front recovery loop is the devil's design and if one is not going off-road with intensity, it's worth whatever effort you desire to impart to expose the loop.
Enjoy!
nashvegas (10-17-2022)
