GAP IID Tool Summary
Below is a copy and paste from the good work of Hairy Dan at Defender2.net. I thought I would post it here for others like myself in this forum to avail of. I just got my tool and hope this thread can be added to as more activations come on stream.
Thanks @Dan Hairy . I know you and other contributors on here have done the hard work but a unified thread does not exist here. Till now.
Cheers. Happy activations.
__________________________________
I have tried to collate all the known working settings into this post, if anybody spots a mistake or has an addition to make just shout
- Activate WIFI/WLAN Hotspot
MultiCAN-814 IVIWiFiHotspot
Standard: Not fitted
Changed to: Internal WiFi Hotspot fitted
- Change Splash Screen to "Defender 007"
EUCD-205 Racing Sub Brand
Standard: Mainstream Vehicle
Changed to: LTD 007
- Dynamic Mode
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
-Remember Stop/start setting
MultiCAN-566 MHLastUserMode = Enabled
For Walk away locking and Approach unlocking the general rule is that it is only available on MY2023 onward, if you don’t have a locking fuel cap you can enable both. You will also have to go into your centre screen setting and switch it on. Some people with earlier cars have got this to work but it is a bit of a lottery
-WalkAwayLocking
MultiCAN-505
Change it to Current: Enabled
-Approach unlocking
MultiCAN-807 Approach Unlocking
Disabled
Change to Enabled
-Modify signature LEDs behavior
MultiCAN-463 DRLBehWhilstDIsAct
Current: Turn Off
New: No Action
MultiCAN-465 DRLBehWhHazardsAct
Current: Turn Off
New: No Action
This setting is to keep them on while the turn signals or hazard lights are operating.
- The subwoofer was installed in the base model, but wasn't enabled.
EUCD-121 Subwoofer
Standard: Without Subwoofer
Changed to: Subwoofer
-Enable All Microphones
EUCD-126 Microphone = Four Microphones (Two Front & Two Rear)
Standard: Microphone (Driver Only)
- Disbale Seatbelt Reminder
MultiCAN-717 Front Belt Minder
Beltminder Fully OFF
- MultiCAN-770 Remote Release Tailgate
Enabled
This will make the rear door pop open when you press the button on the key fob
-MultiCAN-723 Gloabal open/close
MultiCAN 723 SMRF Global Close - changed to Enabled
MulitCAN 719 CDL Global Close - changed to Enabled
MultiCAN 719 CDL Global Open - changed to Enabled
EUCD 184 Global Open/Close - changed to Global Open/Close Doors + Sunroof
- Configurable TR
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout
Edit: Added activations from users below. posts 2-4
Thanks @pjeski @chpsk8
Disable drive away locking
MultiCAN-740 Drive Away Door Lock to Disabled - To disable drive away locking
Leaves foglights on with high beams
EUCD-018 Foglight Function Foglight without restrictions
MultiCAN-734 Front Fog Lights Oft High Beam. Set to Disable.
This one's a wildcard, but I see it works for some people.
Tow Assist Functions
ultiCAN-579 Tow Assist Set to Tow Assist 2
MultiCAN-635 Towing Set to Not Support if not already set to this setting.
MultiCAN-696 ATCM TA2 Switch Set to Tow Assist 2 feature selection switch not fitted, again if not already set to this.
MultiCAN-793 TA2 Input Control Set to HVAC rotary.
MultiCAN-795 TA2 Select in FCPB Set to Rotary used for selection within touch screen
^^^^Resetting PIVI with a something attached to the electronics can help activate this. @BraveSirRobin
Shuts off rear belt minder
MultiCAN-737 Rear Belt Minder
Rear Beltminder OFF
Edit: Information added from DRL thread.
@umbertob
Disable DRL without headlights being on
I think I have found a way to disable the DRL feature in our premium headlights, it involves changing one MultiCAN parameter in the CCF:
MultiCAN-468 FntDRLType
Current: Incorporated DRL and Pos
New: No DRL
Disable Brake Hold
MultiCAN-711 Auto Hold
Was: HVH Enabled
Is: HVH Disabled
Edit:
Thank you @cmpugh7
Disable Auto Fold Mirrors
This worked on my 24-
Had to disable both. Menu--Car Config--Complete list;
MultiCAN-703 Exterior Mirror Auto Unfold
EUCD-085 Rear View Mirrors, Outer
Additional Copy paste from Defender2.net
- After retrofitting 11.4" display
MultiCAN-641 FrntUpperDispVariant
Alpine 11.6 inch Single View
Clarke4x4's thread on fitting larger screen
https://www.defender2.net/forum/topic89297.html
- After retrofitting ClearSight Interior Rear View Mirror
MultiCAN-711 Interior Mirror Variant
IRVM
changed to SVRM
*Requires Gen 4. GAP Tool. These are confirmed to work.
Adaptive Cruise Control.
The G4 tool successfully activated ACC with the following CCF settings:
MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted
MultiCAN-712 ACC Lead Car Distance Display: Fitted
MultiCAN-809 ACC Stop Gap Setting: Fitted
It initially resulted in the “Emergency braking assistance not available” message, but that went away after restarting the engine a couple of times.
Park assist settings
Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears)
Vehicle Leveling Feature (When camping, this can allow you to get that RTT just right)
pending
Changed to: LTD 007
- Dynamic Mode
EUCD-245 Dynamic-I
Changed to: Fitted
-WalkAwayLocking
MultiCAN-505
-Approach unlocking
Disabled
Change to Enabled
Current: Turn Off
New: No Action
Current: Turn Off
New: No Action
EUCD-121 Subwoofer
Enabled
- Configurable TR
Rear Beltminder OFF
@umbertob
New: No DRL
Disable Brake Hold
Was: HVH Enabled
Is: HVH Disabled
Edit:
Thank you @cmpugh7
IRVM
changed to SVRM
Change to: Fitted
MultiCAN-602 PDC
- Needed 2 resets to PIVI for the app to appear in PIVI and a full car shut-down to clear the "Emergency Brake Assist Unavailable" error.
pending
Last edited by GavinC; 05-07-2024 at 09:58 PM. Reason: Added activations. edited to Tag @Dan Hairy
The following 15 users liked this post by GavinC:
bowhun2r (09-26-2023),
D110Xd (06-18-2024),
Dan Hairy (09-23-2023),
Defendeth (05-13-2024),
Elektrapops (07-29-2024),
and 10 others liked this post.
Also from the same site as above:
pjeski (09-07-2023)
The following 3 users liked this post by tbrown:
I've been trying tonight to do some simple activations. No success so far. It always says update failed at the end.
I'm sure it’s something I’m doing or not doing correctly.
The tool is activated and I’m able to use it for suspension height changes but no changes Wi-Fi or global close were successful.
I’m a bit of a dunce when it comes to this stuff. Seems it’s more complicated than I thought.
GAP-eLift works well.
Try updating the firmware on Gaptool IID. There was an issue several people were reporting on the other board that was same thing.. I think they were all people who'd just purchased Gaptool IID and were using it out of the box. I think a firmware update fixes it. It's a tool issue not a car issue?
chpsk8 (09-08-2023)
