Goodyear Wrangler Duratrac ???
Not specific to the duratrac's but in terms of driving dynamics and the question of going plus size: I did the Johnson Rod 1.5" lift and went with BFG K02's in 275/60/20. After a 1000K miles highway, snow, dirt and gravel roads... (of course it's better off road) while slightly louder, I am extremely impressed with driving dynamics on road and highway. I do not see a down side in terms of height with the lift or tires. I think if you're selecting a slightly bigger size you will not experience any downside.
They don’t sell the duratracs from the factory because that would lower their fleet mileage numbers which they need to keep up as much as possible. And for all the other reasons cited about the Adventures being better for most buyers. If you live in snow country and want to drive during and right after storms, you should just get a spare set of wheels with winter tires. None of the three peak AT’s will be as good especially on icy packed roads. You could also look at KO2’s which are three peak rated, but again not nearly as good as a winter tire on icy roads.
Load Rating is a indication of toughness measured by the max PSI rating, XL implies 42 PSI, but both the 275's and 255's have a max of 50PSI. This would imply they both exceed the XL rating, no idea why it's not stamped on the 275's, guessing it's a certification/red tape thing. The 275's have the same load index (113) and max inflation pressure (50psi), so they can carry the same weight as the 255's, and are just as tough. The 275's also actually have a higher speed rating, so they are actually a higher rated tire.
Thanks again for the feedback thus far...I didn’t realize when I began this search that selecting a new tire would require this much research. I’m a rookie when it comes to speed ratings, load ratings and overall tire specs. Seems the easy answer is the Duratrac however there is a significant difference in the speed rating between that and my current Wrangler ATs. In the end I know it will come down to personal preference, hearing recommendations or getting input is helpful none the less.
The hunt continues...
Bottom line is, do NOT second guess the engineers that built your car and run a SL/ standard load tire if it requires XL or greater, it could spell trouble on-road and especially off, besides possibly invaldating your factory warranty / insurance if the dealer / adjustor can somehow blame the unsuitable tires for a breakdown, blowout or accident.
Here are a couple of good articles that explain the difference between SL and XL tires, in plain English.
https://www.prioritytire.com/blog/st...load-xl-tires/
Barry's Tire Tech
TrioLRowner (02-12-2021)
^^^ JLR recommendations copied straight from manual, matches label on drivers side frame... although the label on the car says the cold PSI should be 47/50 (e.g., shows the "normal" pressures from the manual vs light load).
Question -- should these factory fitted tires really be inflated to 47 front / 50 rear? Isn't that crazy high?
DefenderSmitty (02-20-2021)
https://landroverforums.com/forum/20...r-l663-104449/
The following 2 users liked this post by TrioLRowner:
DefenderSmitty (02-20-2021),
LRDEF2LR (04-28-2022)
