Hitch Mounted Bike Rack on a 110
Old 03-21-2021, 08:52 PM
crewcabrob's Avatar
Originally Posted by MrBreeze
Sweet set up Rob!
Any movement on the road with the RackAttach? Are you able to fold up the 1Up rack and still clear the spare?
BTW - Nice choices on MTB's! I've got a StumpJumper Comp, 2 Levo's (my wife and I) a Vado (mine) and Como (hers) - the e-assist bikes are as much fun I've had on a bike since I was 12 years old...
Hi,
No movement from the Rack Attach, it's solidly bolted to the hitch with the anti rattle device. I can fold up the 1up rack, and clear the tire. What I didn't check was to see if when down and not loaded with bikes, if the rear door clears the top of the bike rack. I will give that a try when I go riding next.
I'm a diehard Specialized guy, and love your stable of bikes. Sounds like you have way more than I do. I have tried to limit myself to only 1 expensive bike at a time. I might change that next year.
Rob
Rob
  #52
Old 03-22-2021, 01:45 AM
TT2212's Avatar
Looks Awesome! Setup and Bikes! Appreciate the photo with the swing arm action.
I've got the 1up Heavy Duty using four down to two bikes, works great even with one a Levo (ebike), and I'm using the 7" AntiWobble to work around the spare, but planning on replacing the extension with the RakAttach,
Q just confirming that is the "Large" size you have (vs medium).
  #53
Old 03-22-2021, 01:20 PM
TT2212's Avatar
I use 1up too and love it. Been looking at the rakattach vs kuat Pivot, Q: how does the pivot deal with anti wobble in the connection to the defender's hitch, is there more than the safety bolt to keep the pivot wiggle with the defender hitch solid? How easy is it to inspect & retighten. I have an old kuat rack that had a nut wiggle loose, like all things probably needed more regular inspection of all connections. Thanks!
  #54
Old 03-22-2021, 06:08 PM
majl's Avatar
Originally Posted by Ipe
Single rack folded up
Great to see all these different options and the real world thoughts from owners who have actually been living with these racks. In the pic quoted here, will the spare tire and rear door clear the tray so you can fully open the door?
  #55
Old 03-22-2021, 06:40 PM
crewcabrob's Avatar
Yes, I ordered the large version.
Rob
  #56
Old 03-22-2021, 06:42 PM
crewcabrob's Avatar
There is a lock on the other end of the bolt, so you wouldn't have a total catastrophic failure, By the time it would loosen, you would likely hear it banging around in the hitch going over bumps.
Rob
  #57
Old 03-22-2021, 11:22 PM
MrBreeze's Avatar
Originally Posted by crewcabrob
Hi,
Rob
Rob
Great info Rob. Thanks.
It would be nice to be able to leave the RackAttach and 1Up attached for the better part of the season and knowing you can fold it up behind the spare means not having to take it on and off all the time. I'm currently using a Thule T2 Pro XT on my RAM 2500, but always taking it on and off each time I use it as with it mounted and folded, the truck is too long to fit in the garage with it installed. Fortunately, the rack can be loosened by hand. Once the Defender arrives, the length is less so it should fit in the garage with the rack attached.
Scott
  #58
Old 03-23-2021, 06:58 AM
Ipe's Avatar
Ipe
Ipe is offline
7th Gear
In this position, NO, it will not clear. In the horizontal position, YES, it will clear the single rack. I didn't try the double but there's minimal clearance (maybe 1/2") with the single so I really doubt a double will clear.
majl (03-24-2021)
  #59
Old 03-23-2021, 07:03 AM
Ipe's Avatar
Ipe
Ipe is offline
7th Gear
Kuat tightening device is very similar to 1UP. It is VERY secure with essentially NO rattle, sway, wiggle, etc.
When I assembled it I used blue loctite on all bolts. That should help the lock washers do their thing.
  #60
Old 03-24-2021, 02:55 PM
majl's Avatar
Thanks for the reply; this is what I needed to know. Doesn't look like I will be able to leave it mounted then since the Defender will be my wife's vehicle. She will not want to deal with folding the rack up and down every time she wants access to the rear.
Quick Reply: Hitch Mounted Bike Rack on a 110
