How to look options by VIN?
How to look up options by VIN?
Hello,
I'm looking at a 2022 D90. I want to know what options are on it but the seller (a used car dealer) does not have the original sticker. Is there a way to look up the build/options using the VIN?
Thanks in advance.
Thanks in advance.
https://landroverforums.com/forum/vindecoder.php
You could run it through there, that'll get you the body style/engine, but options aren't normally encoded in the VIN
you could reach out to your local LR dealer and see if they can pull a build report? I've never tried this but have seen this done with Toyota.
MrBell (10-27-2022)
you can pull the buildsheet and any other service records from https://topix.landrover.jlrext.com/
However you'll need a subscription for that. You can get a very short one i.e 1hr if you just want to pull something really quickly
Or the other option is to ask the dealer nicely to pull if for you as they would usually have a subscription
Royalist (11-05-2022)
