Integrated Air Compressor or ARB Compressor
Please disregard this post. After I posted I found the thread. Couldn't find it using the search function but as soon as I posted my question all the related threads showed up! Rookie mistake, my bad.
Once I figure out how to delete this post I'll be in business. Thanks for your patience
Howdy folks, first post for me. Got a deposit in at my local LR dealer and looking at a September delivery for an Eiger gray Defender 110, 6 Cylinder. Still havent finalized my build.
Questions for the herd:
If you have the integrated air compressor, Is it worth adding it to my build or would it be better to add an ARB setup after I take delivery?
If you have an ARB setup, which one did you get and where did you mount it?
Gracias
Gracias
Last edited by jwasson68; 12-29-2020 at 07:58 PM. Reason: found the answer after I posted.
Gracias
Gracias
on
What did you get in your factory order that you could not get off the lot?
To be honest I didn't check with Denver, so not sure what the queue is like up there. Im in no rush so no reason to chase down other options. My Co Springs dealer didnt offer me anything yet, except the super sweet Lego set!. I paid a $1K refundable deposit to get in line, and in May/June I'll finalize my build. They did say if I order the 4 Cylinder that my deposit probably wouldn't be refundable since they aren't seeing much demand for those. I'm going with the 6 Cylinder so that doesn't matter for me.
If I was in a rush I could take something off the lot but the ones that are available on my lot didnt have the electronic active differential except for one which was priced at something like $83K.
They said they can also work with other LR dealerships across the nation to get something sooner but September works for me.
Also - Denver dealers queue was worse. They have buyers lined up for the foreseeable future when I called to check on what they had. Think the Springs has less foot traffic than the Denver one.
