Integrated Air Compressor software update
Has anyone successfully done the software update for the integrated air compressor?
LR has the procedure on their official instruction for installing the integrated air compressor by using the phone app "LR IAC Update"
However it requires a login account which can only be provided by LR, I tried to contact service department of my local dealership, they seem have no idea what I talked about.
after experiencing difficulties with getting help from the service department at one of my local dealership. I called the LR North America for help, after multiple tries explaining what it is, I was told that local service department are the one who can give access to the update. All they need is to be provided with the reference# from the pdf file which shared by @nashvegas , and they should have an idea then. However, I have not tried yet to contact the dealership again.
Thanks for notifying us of this. Mine has always work (except for the new issue mentioned below), but occasionally I get the error messages. A off/on cycle seems to clear it fine. I've downloaded the update and scheduled for my 20K mile service soon, so I'll ask my dealer as well.
On a side note, my compressor is reading air pressures about 10-13 pounds lower than actual. In other words, I have to set it to pump to what it thinks is 59 psi in order to get about 47 psi into the tire. It has functioned perfectly until just recently. It still pumps air and makes adjustments, but it off with its pressure readings. It's like it needs to be reset or re-calibrated for accurate pressure readings. Maybe the software update will help.
Well that's not good to hear @gts944 I was on a trail run today and compressor was fine, but when I was airing back up (I know I know) the 4th of 4 tires at the end of the run, I got a repeated E4 code and it wouldn't work. Power cycle and it'd work for 1-2 mins. Then E4 again. Eventually it was fine after 3 power cycles. I did not see any hieroglyphics on display during this.
Well that's not good to hear gts944 I was on a trail run today and compressor was fine, but when I was airing back up (I know I know) the 4th of 4 tires at the end of the run, I got a repeated E4 code and it wouldn't work. Power cycle and it'd work for 1-2 mins. Then E4 again. Eventually it was fine after 3 power cycles. I did not see any hieroglyphics on display during this.
