Keyless Entry/Start Not Reliable
My keyless entry doesn't work very well. After the car has been locked for over 20 minutes (sleep mode), you have to push the button on the door handle many times for the Defender to unlock. The same upon entering the car, often you can't use the push button start until it recognizes the key (15 to 30 seconds). This only occurs when the keyfob is in my front pant pocket. If the keyfob is in my hand or I use the buttons on the fob, everything works normally.
I took it in for service to troubleshoot it. I got the dreaded, "We couldn't reproduce the problem." response. Later I found out the Technician had the keyfob in his hand or breast pocket when testing. I did tell them it only happens when I have it in my pant's pocket. Also, left a note in the car explaining the problem to the Technician.
Anyone else have this issue. The dealer said they had 2 other Defenders in for the same problem. Imagine that. Maybe I'll just sew special key pockets to all my shirts.
noor440 (04-06-2021)
My keyless entry seems to be cursed with the same issue. It feels like a crapshoot whenever I walk up to open using the button on the driver's door. Often it's easier just to unlock via the rear passenger door. It seems like it's maybe related to the proximity sensor not picking up the key when in my right pant pocket as I approach the car from the rear and then press the door button.
For me, it's 80:20 whether it works. Locking works every time. If I am parallel with the middle of the door it seems to work better. (Maybe that's wishful thinking that it's not just LR unreliable tech at work).
However, zero issues with push-button start.
Kev M (05-02-2021)
I have the same issue with both the unlock of the front driver's door and the start/stop button. Only happens when unlocking the door and starting the vehicle. It's at the dealer now to address the "emergency steering and emergency braking unavailable" issue which has been happening since the day I picked it up. I need to tell them about the unlocking issue as well. It is annoying.
Very often won't unlock when I push the driver's door button but will for the driver's side rear passenger door.
Hit or miss with the keyless start but have often had to pull it out of my pocket.
Same issues for me. Driver door button has random moods of working and not working. Won't start with the fob in my left pants pocket, prefers I keep it in my right pants pocket. Maybe intentional to honor the tradition of British auto electronics.
Our LR4 fobs work great, from really far away. Can lock/unlock from 100 yards away. LR4 senses when you are close and unlocks when you pull on any door handle. No button to push. You can put an LR4 key fob in a duffle bag in the way back and it starts perfectly. Amazing LR was able to take a step back in fob technology with a new model.
noor440 (05-03-2021)
