More Rattles…
More Rattles…
Has anyone dealt with a rattle originating from above the drivers side door area? Almost sounds as if it’s coming from directly behind me, driving me absolutely crazy. Very faint, but seems to have gotten a worse with time.
I spent an hour or two rubbing down all seals with the Honda grease to no avail. Any ideas on what this may be? It seems more noticeable on rough roads.
Lnberger (12-10-2022)
I can’t seem to reproduce this pressing on the roof around the folding grab handles. Very very frustrated with this problem, the dealer claims they could not reproduce. I’m at a whits end here.
What did your rattle sound like? Mine can almost be described as plastic clicking together (or a wire/lebel of some type)? It seems to get worse when I speed up as well. I was really hoping it was just a dry rubber seal.
I spent the better part of 2 hours greasing all the seals, not sure that’s the cause. I did notice the large black seal area on the upper rear section of the window opening creaks when pressed, but not sure that’s the source. I’ve almost lost hope.
I have this, or at least a very similar, issue on my 2021 110HSE. It seems to be coming from somewhere inside the roof liner between the driver's door handle and the sunroof. My guess is that there's some wiring or something in there that's rattling a bit when I go over bumps.
I tried re-fitting the grab handle hoping it would help, but no luck. My next step when I get around to it is to look inside the headliner with a boroscope. I'll post back here if/when I learn anything interesting.
Count Laszlo (12-10-2022)
I just picked up my new p300 130 this week and that rattle or rather creaking is in the headliner at the drivers side door.I heard it when I hit a pot hole.I, can recreate the sound by pushing on the headliner right above the door. It sounds like crumpled plastic. Other than that, this vehicle has been great.
