Need advice on towing
I have a 2022 Defender HSE P400 with the advanced towing package. I am thinking of getting a 5000 lb trailer camper. Do I need to get an electric brake controller or does the advanced towing package include that? I have the harness by the tow hitch but my instruction manual is saying that I need to get a separate brake controller. It’s a bit confusing.
any help and insight would be much appreciated!
If I had a trailer and planned on keeping the Defender for a few years I'd go the former route.
As I plan on just towing infrequently I went the latter route and got this.
It's less than ideal given the position of the wiring harness in the defender but will do the job. Not used it yet. The advanced tow assist does not have any brake control features. It gives you the fun steering feature in addition to the standard towing camera stuff. You can see that here
http://www.facebook.com/groups/68627...3851579426060/
GrouseK9 (05-16-2022)
Absolutely get a brake controller. The vehicle tow rating is with a controller. It does not come with the advanced tow package. It is pre wired for a brake controller under the dash. You just purchase one that you like and get the ford/LR harness. Then just find a place to mount it. Here is where i put mine.
You will need these two items, available on Amazon, and a bit of dexterity to mount it under the dash .....
Enjoy!
Enjoy!
I'd be suspicious of the Curt wireless unit. The trailer brakes need a lot of current, which is not necessarily supplied to the 7-pin trailer socket. When you connect a controller to the harness (above the driver's feet), you feed the "brake" wire (which is heavy duty) from an appropriate supply and this goes all the way to your brakes. See also https://landroverforums.com/forum/20...roller-101917/. I copied this and it works really well.
