P300 Cooling Fan
Old 04-05-2022, 10:38 PM
kpd122's Avatar
Default P300 Cooling Fan
Anyone else with a P300 experience the cooling fan run at full speed after shutting the car off? MY22 P300 will ramp the cooling fan up to max power any time you park and let it idle for more than maybe 10 seconds. This happens any time its over maybe 65 degrees ambient, which is most of the time in Phoenix. Slightly irritating, and people occasionally ask if I've left the car running accidentally. This will be the car's first summer, and I can only imagine how long it'll be roaring away in the parking lot.
Old 04-06-2022, 10:10 AM
gb_junkie's Avatar
my p300 does this 20% of the time after I shut it off, reminds me of my crapped-out hot hatches back in the day with turbo timers. i think it's normal.
TrioLRowner (04-06-2022)
Old 04-06-2022, 10:43 AM
TrioLRowner's Avatar
Mine is the same as gb junkie. I am not in a hot region of the country. Still, it has happened more as Winter has departed.
Old 04-06-2022, 01:05 PM
DGINAZ's Avatar
I have a 2022 P300 and also live in Phoenix - I notice the fan running after turn-off about 20% of the time. I picked my Defender up back in Sept 2021 and we had some pretty hot days - no real issue with the fan. If yours does seem to run a lot, I would have the dealer take a look at it.
Old 04-06-2022, 02:00 PM
Norsk's Avatar
Mine does it in Florida. Just doing its job, heat kills engine components.
Old 04-06-2022, 04:51 PM
kpd122's Avatar
All of my turbo Volvos ('09-'15) would do it, but only if I ran them real hard before shutdown.
Good to hear feedback from someone else in AZ. Ours is basically guaranteed to do it if you don't park and shut it off instantly. I'm not so worried about the behavior of the fan - I'd expect it to run if things were real hot. I'm just wondering if a sensor is inaccurately reporting. Though I suspect that's something the dealer will never bother with diagnosing.
Old 04-07-2022, 09:03 AM
MattF's Avatar
Related to a degree - my Audi RS6 (V8 twin turbo) will run the fans (actually its running the cooling system) every time I turn it off. No matter the weather etc. This is done to keep the coolant running through the turbos to manage heat... wonder if it might be similar for the Defender.
Matt
TrioLRowner (04-07-2022)
Old 04-07-2022, 09:16 AM
kpd122's Avatar
Matt
The thought occurred to me, especially with how much power these 4-cyls put out these days. I don't doubt the turbos put off massive amounts of heat. Do we know if the Defender turbo is water cooled? I haven't bothered to investigate under the hood much - too many other project cars for me to bother with it. I'm sure the water pump is electric, so it could definitely be circulating coolant after shutdown.
Old 04-07-2022, 10:21 AM
Barstoolman1127's Avatar
When you say irritating, you mean you are bothered by the fact that the fans are doing what they’re intended to do? SMH!
Old 04-07-2022, 11:15 AM
P300 Turbo is water - cooled and the oil needs cooling, also.
And it seems to somehow be able to independently spin as it cools, or so it sounds to me when it is hot and the engine is off. I recall there appears to exist a small pressure tank which bleeds to turn the impeller.
Land Rover Defender 110 Engine Parts
[size=13px]This Fits Your 2020 Land Rover Defender 110 S Sport Utility 2.0L Ingenium A/T[/size]
View Full Size
TURBOCHARGER & COMPONENTS.
2. 0 liter. Lower. Outer. Top. Upper.
Add All to Cart
    Product Name
    Price
    Part Number
    Qty.
  • 1
    EXHAUST MANIFOLD. Turbocharger.
    2.0 LITER. A complete turbocharger assembly. Exhaust Manifold. Incl.Integrated Exhaust Manifold. Incl.Turbocharger. Includes Exhaust Manifold On The 2.0L Gas And 3.0L Engine. Includes Exhaust Manifold On The 2.0L Gas Engine.
    (Current price)$ 2,129.76
    LR116338
    Add To My Cart
  • 2
    Gasket. Manifold. Exhaust.
    2.0 LITER. Turbocharger gasket. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Manifold Gasket. Turbocharger Gasket.. Turbocharger.
    (Current price)$ 29.35
    LR091554
    Add To My Cart
  • 3
    Gasket. Converter. Turbocharger. Seal.
    2.0 LITER. Turbocharger seal. 2.0 LITER. 2.0 LITER GAS. 2.0 LITER GAS 2021. 2.0 LITER PHEV. 2018-21. A component which prevents a leak or provides a sealing surface at the Catalytic Converter. CONVERTER & FRONT PIPE. Gasket for Catalytic Converter System. Outer. Outlet. Turbocharger Gasket. Turbocharger Oil Seal. AND pipe. Oil. TURBOCH. Catalytic. FLANGE. MANIFOLD.
    (Current price)$ 22.13
    LR105411
    Add To My Cart
  • 4
    Clamp. Converter. Pipe. Exhaust.
    2.0 LITER. 2.0 LITER Gas 2018-20. 2.0 LITER Gas 2021. 2.0 LITER PHEV. Catalytic Converter Clamp. Clamp for Exhaust.. and. Catalytic. Turbocharger.
    (Current price)$ 63.02
    LR105414
    Add To My Cart
  • 5
    Shield. Heat. (Upper)
    2.0 LITER. Heat shield. PartQualifier: upper. upper. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Heat Shield. Turbocharger Mount Heat Shield. TU. Exhaust. Turbocharger Mount.
    (Current price)$ 31.97
    LR091546
    Add To My Cart
  • 6
    Shield. Heat. (Lower)
    2.0 LITER. Heat shield. lower. PartQualifier: lower. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Heat Shield. Turbocharger Mount Heat Shield. TU. Exhaust. Turbocharger Mount.
    (Current price)$ 24.37
    LR091551
    Add To My Cart
  • 7
    2.0 LITER. Heat shield. PartQualifier: top. top. Upper. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Heat Shield. Turbocharger Mount Heat Shield. TU. Exhaust. Inner. Turbocharger Mount.
    (Current price)$ 26.15
    LR091550
    Add To My Cart
  • 8
    Shield. Heat.
    2.0 LITER. Heat shield. outer. PartQualifier: outer. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Heat Shield. Turbocharger Mount Heat Shield. TU. Exhaust. Side. Turbocharger Mount.
    (Current price)$ 22.77
    LR091549
    Add To My Cart
  • 9
    Turbocharger Coolant Line
    2.0 LITER. Water inlet.
    (Current price)$ 55.66
    LR092089
    Add To My Cart
  • 10
    2.0 LITER. Water outlet.
    (Current price)$ 54.95
    LR134606
    Add To My Cart
  • 11
    Hose. Coolant. Line. (Upper)
    2.0 LITER. By-pass pipe. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Engine Coolant Hose. Line used to transmit oil amongst the turbo, interCooler and Engine. Turbocharger Coolant Line. By - Passenger pipe. Engine. Turbocharger Oil.
    (Current price)$ 57.06
    LR108956
    Add To My Cart
  • 12
    SEPARATOR. Water. Coolant. Valve.
    2.0 LITER. 2.0 LITER GAS. 2.0 LITER PHEV. 2018-19. 2018-21. A manifold vacuum actuated valve designed to release pressure in the intake system of a turbocharged engine when the throttle is lifted or closed. Radiator Coolant Hose Adapter. COOLING. Radiator Hose Adapter. Turbocharger Intercooler Diverter.
    (Current price)$ 82.46
    LR093489
    Add To My Cart
  • 13
    Turbocharger Oil Line
    2.0 LITER. Oil feed tube.
    (Current price)$ 56.21
    LR091576
    Add To My Cart
  • 14
    Turbocharger Oil Line Gasket
    2.0 LITER.
    (Current price)$ 4.85
    LR073671
    Add To My Cart
  • 15
    2.0 LITER. Oil return tube.
    (Current price)$ 34.61
    LR100575
    Add To My Cart
  • 16
    Ring. Oil. Tube. (Upper)
    2.0 LITER. Oil return tube o-ring. PartQualifier: upper. upper. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. 2018-21. 3.0 LITER I6 Gas. 3.0 LITER I6 MHEV. Return. Turbocharger Oil Line Gasket. Turbocharger Oil Line O-Ring. Upper. Sealing. Drain o -. Outlet o -. Return Seal. Turbocharger Line Gasket. Included with: Oil Return Tube.
    (Current price)$ 4.96
    LR136779
    Add To My Cart
  • 17
    Ring. Oil. Tube. (Lower)
    2.0 LITER. lower. Oil return tube o-ring. PartQualifier: lower. 2.0 LITER. 2.0 LITER Diesel. 2.0 LITER Gas. 2.0 LITER PHEV. 2018-19. 2018-21. 3.0 LITER I6 Gas. 3.0 LITER I6 MHEV. Lower. Return. Turbocharger Oil Line Gasket. Turbocharger Oil Line O-Ring. Drain o -. Outlet o -. Return seal. Turbocharger Line Gasket. Included with: Oil Return Tube.
    (Current price)
Quick Reply: P300 Cooling Fan
