P400 goes from 20inch to 18inch Evo Corse Dakar Zero
Old 11-06-2021, 02:38 AM
aao4473's Avatar
Originally Posted by GrouseK9
Agree with @_Allegedly , the pictures are worth a 1,000 posts! Ok, I do have one question: what grit on the angle grinder? Did it throw a lot of sparks? Been thinking of doing that but was thinking I would need to put a lot of padding around to keep from scorching paint/etc. Also, did you just eye ball it or did you measure it for how far you wanted to grind? Ok, three questions...
to be honest I dont know what grit was used but I can ask, and no sparks at all, you can use a bit of oil on the caliper and then grind.
for the first try we used chalk powder on the caliper, put on the rim, wiggle it a bit then take it of, check which place was touching on the caliper.
for the other caliper we knew how far to grind.
it was literally less then 30 mins.
Old 11-06-2021, 02:40 AM
aao4473's Avatar
Originally Posted by stevenopoly
this might be a stupid question, but it looks like the clearance between caliper and rim is very small. Aren't you afraid of rocks getting stuck inbetween?
I know the picture doesn’t show the Clearence, but ill take better pics from behind the wheel to show you the clearance.
just waiting for my tires.
stevenopoly (11-06-2021)
Old 11-06-2021, 02:48 AM
aao4473's Avatar
Originally Posted by mammoth
This is awesome! Something else to consider - you can actually order the smaller calipers that lucky8 sells directly from LR, and it's much cheaper. The smaller calipers are actually what come on the p400 defender if you order it with 22" wheels (but those vehicles have bigger rotors, which is another issue). Pretty sure that the lucky8 ones are made at the same factory, albeit without the LR part number on it. Not only was it cheaper to order the genuine LR parts, but if for some reason I have to take the defender in for service and they remove the wheel, the tech will see a LR part number and probably not realize I've modded the vehicle.
I thought about, its a hassle, ordering parts, paying labor fees, brake bleeding and ecu recalibration etc.
Even if I bought the lucky8 conversion kit, its the same thing.
5 wheels were give or take the cost of the above parts.
the only thing im worried about, is if I installed a new pad, will it change or grind more, which will answered once I change the pads.
Old 11-06-2021, 04:06 AM
Defendit..'s Avatar
Nice job !, well done
I would grind a little bit more off, looks like there is enough material left.
Old 11-06-2021, 04:37 AM
aao4473's Avatar
Originally Posted by GavinC
Thanks for the great post and pictures.
I presume this will work with Tuffants also.
I'm asking Santa Claus for an angle grinder.
yes definitely will work with the tuffants!
GavinC (11-06-2021)
Old 11-06-2021, 06:42 AM
aao4473's Avatar
yes there was room for more grinding, but im curious about when its time to change the pads, will it move or push the caliper outwards.
Old 11-06-2021, 06:51 AM
4x4 DAVE's Avatar
Location: Summer in Upstate NY, Winter in South Florida, Spring and Fall in Kentucky
If changing the pads pushes the caliper outward and that then creates an issue wouldn’t a set of spacers solve the issue?
Old 11-06-2021, 07:24 AM
aao4473's Avatar
ill be receiving my tires this upcoming Thursday, will go over the setup again and check.
maybe add a 10-15mm spacers later.
Old 11-06-2021, 09:09 AM
Defendit..'s Avatar
10 or 15 mm. Spacers are disks, You don't want that.
minimum will be 20mm with new bolts and lugs.
Old 11-06-2021, 12:58 PM
aao4473's Avatar
confirmed, changing the brake pads doesn’t move the caliper.
The following 2 users liked this post by aao4473:
LostChord (09-20-2024), stevenopoly (11-06-2021)
Quick Reply: P400 goes from 20inch to 18inch Evo Corse Dakar Zero
