P400 Towing
I’m expecting delivery of my P400 in Feb/March timeframe and was hoping to get some feedback of anyone whose towed with it.
We plan on towing a 25’ travel trailer that weighs roughly 5k lbs fully loaded. The manual recommends against using a weight distribution hitch (WDH) but it’s worked great for us on our other tow vehicle - X5 M50i, to counteract sway. Has anyone towed something similar with/without a WDH with their P400? Any thoughts on why LR would recommend against using one?
Thanks!
Thanks!
My LR4 also recommended avoiding a weight distribution hitch, but we used it, and it worked well for 10 years towing 1 23' single axle travel trailer, and at the end a 26' 2 axle travel trailer. The first time we towed with the Defender we continued to use the the weight distribution hitch, like you, I think it makes a difference in regards to sway. I'm not certain how well the BMW tows, but both Rovers tow extremely well particularly with the towing pack. The P400 easily accelerated to 75MPH, I set the cruise and it never seemed to struggle, not did I ever feel any hint of sway (I assume without my hitch there would have at least been some). The only down side was the mileage, the first 100 miles we only achieved 6MPG, I did turn it to "Eco" mode afterwards and it seemed to do much better, but as it was mixed driving afterward I don't know the actual MPG.
So to answer your question I believe in using a weight distribution hitch and use it on my Defender, just as I did my LR4 before. With a trailer of 5000lbs I don't think you'll notice any performance issues putting the car into ECO mode, but I do believe it will help gas mileage.
LR4USN (12-05-2020)
I believe it is not necessary to use a weight distribution hitch on a JLR product with active air suspension, because the vehicle adjusts the suspension force in real-time based on what is necessary to maintain a level, controllable ride. The rear axle is designed to carry this load and the braking capability and computer logic of the vehicle is designed to have the rear axle under a much heavier load than the front.
The only theoretical concern one might contemplate is the effect of a weight distribution hitch is to shift weight off the tongue to the other axles in the vehicle and the trailer. Those transferred weights must remain within the specifications of each axle, the overall gross vehicle weight, the ratio of tongue weight to trailer weight, the overall trailer weight and the combined vehicle and trailer weight. I think the JLR engineers might be concerned that under a weight distribution hitch the front axle may be either under or over - loaded because of the weight re-distribution.
in any case, I suspect they might say that if the weights are within specification and the air suspension can happily level the vehicle, all is fine.
GavinC (03-21-2022)
The following 2 users liked this post by turf63:
Dewman7770 (12-07-2020),
TrioLRowner (12-07-2020)
If you search the web for weight distribution hitch and unibody vehicles, you’ll find many an explanation as to why it’s not recommended. If the Defender manual says not to use one, it’s probably for the same reasons other unibody vehicles come with the same guidance. Clearly a use at your own risk type of situation.
Thanks all for you thoughts and perspective. Being an engineer myself, I understand the stress a WDH applies to a unibody; however some unibody vehicles do allow the use. In the manual, it states that they are “not recommended” instead of “not permitted”; I was wondering if anyone had seen any formal communication from LR strictly not to use a WDH on with the new Defender. I’m assuming the issue is with the sway control of the WDH preventing the Defender’s Trailer Stability Control from fully operating. Thanks!
