Proud Rhino Winch Mount Install + Camera Issue
Hi All, just finished installing the Proud Rhino Stealth Pack Winch Mount and Warn VR EVO 10S winch (PROUD RHINO STEALTH PACK WINCH MOUNT – lucky8llc.com) . The winch and tray works really well, and I think the look very clean and practical.
However, after completing the install I've discovered a problem. It seems the front camera is pointing too high, and shows my track "going into the sky". This also makes the front 360 view and under hood view malfunction. Has anyone else installed this kit, and if so did you run into this issue? I suspect what's happening is the camera angle is not preserved when following the instructions provided. The original grill bracket appears to be at about a 15 degree down angle, and the new location appears to be 0 angle. Does anyone know if this can be fixed by recalibrating the camera, or will I need to try and create some kind of shim or new bracket? Odd that the kit would miss this pretty obvious issue. Thanks, any help/advice greatly appreciated!
The other problem is that my metal skid plate needs some kind of bracket that has not been made yet, so I had to put the original plastic skid plate back on. Hopefully the skid plate bracket will be available soon.
The completed install
The new camera location
How the track is projected incorrectly
Thanks!
Thanks!
Thanks!
Thanks!
Yes, eventually (after 2-3 days or so) the camera does adjust and compensate for the new angle, so the issue "solves itself". That said, because of the fisheye effect, I did get a little bit of distortion in the various camera views, although it didn't affect the overall usability/function of the system. When I went to get my skid plate re-installed (after Lucky8 made the required bracket available), I had landrover adjust the camera angle a bit to make it more level. A bracket, or wedge of some sort would be an interesting idea. The camera is stuck on with glue/tape in the install process, which seems a bit weak to me (although I've had no issues).
Fivespddisco
08-15-2017 09:22 AM
WNYErikDiscoII
07-07-2015 08:21 AM
