Range Rover Wheels on Defender (Fitment Question)
Old 02-16-2021 | 04:41 PM
Zereldo's Avatar
8th Gear
Default Range Rover Wheels on Defender (Fitment Question)
Hi, I have a 2020 Land Rover Defender with optional 22 inch wheels.
Specifications:
22x9, offset: 44.5 mm
OEM Range Rover Sport wheels from 2020 Range Rover Sport HSE
Specifications:
20x8.5, offset: 47 mm
Center bore and bolt pattern is identical.
I am worried about the rear caliper clearance. Has anyone installed other non Defender Land Rover wheels on their Defender? Do you reckon it will cause any issues?
Any input is appreciated.
Cheers!
Old 02-16-2021 | 07:22 PM
mnugent's Avatar
I tried putting 18" P38 wheels on and there was not enough offset for the rear calipers. I just got some new 10-ply Yoko Geolanders and was hoping to use those wheel, but will need to find spacers, or different wheels. Anyone have any suggestions on OM 18" steel wheels?
Old 02-17-2021 | 01:14 AM
spikemd's Avatar
I tried putting on a 20 inch rim from my 2010 Supercharged L322 Range Rover and the rear caliper hit the center. Didn't work. And I have the smaller rear calipers on my P300.
Old 02-17-2021 | 08:31 AM
PaulLR's Avatar
Zereldo, I think the 47 offset on the RRS wheels will be the problem. My LR4 wheels did not fit either.
Old 02-17-2021 | 03:24 PM
boni's Avatar
You can use wheel spacers like the Eibach Pro-Spacer Kit (20mm Spacer) S90-4-20-043
That will create enough clearance.
https://www.eibachshop.co.uk/eibach-..._p31222693.htm
Old 01-24-2022 | 03:39 AM
Tozva's Avatar
Specifications:
Specifications:
Cheers!
Hello, did you find a solution? Did the 47mm wheels fit to the new Defender with 44.5 mm original? Without spacers.
I have the same question as i have some 20´ inch wheels from my RR Sport 2019 Hybrid, that i want to fit to my ned Defender.
Jon Christopher Brillhart
10-29-2021 11:59 AM
LRDef
02-17-2021 03:28 PM
Crusader_22
04-01-2020 02:07 PM
Kcouls001
Defender
03-30-2019 03:32 PM
wmccwright
09-19-2006 05:50 PM
