rear climate not working
Old 01-27-2021, 12:51 AM
Ehloo's Avatar
Default rear climate not working
almost a month of ownership and i can’t figure out how to turn the second row on. a first and read the manual and nothing. lock is off, can’t change temps or even control on the screen. manual controls “push” button doesn’t do anything
am i missing something
Old 01-27-2021, 12:23 PM
TCole's Avatar
I don’t have the climate control package but in my car the second row vents work as long as the mid (torso section) air-flow option is selected in the climate options menu. The back vents don’t work when only the lower (foot section) option is selected. It took me a while to figure this out. Hope that helps.
Old 01-27-2021, 11:51 PM
Ehloo's Avatar
i have rear climate and i did check your suggestion and still no luck.
i have a strange feeling that i am not doing something right but why is it so difficult to turn the rear climate on.
Old 01-28-2021, 11:00 AM
DallasBBQ's Avatar
Ehloo - Can you post pictures of your Defender? I would like to see your tire and wheel combination. Sounds great
Old 01-28-2021, 11:29 AM
Ehloo's Avatar
Default pics
only if you can get my rear climate to work! so frustrating
Old 01-31-2021, 07:48 PM
sblvro's Avatar
Can't you turn it ON in the screen?
Old 02-01-2021, 08:55 AM
Ehloo's Avatar
Default climate
wont turn on from screen either
Old 02-03-2021, 09:30 AM
PaulLR's Avatar
I need to figure this out too. It seemed unusually cold inside my Defender and I finally saw that the rear temp dials were set to 60. Turning up the rear controls to 70 solved that issue. My LR4 has a button that allows the rear temp to sync with the front temp OR allows the rear passengers to set their own temp. I need to dig into the manual to see if a sync function exists for when I'm driving alone.
Old 02-03-2021, 11:24 AM
ADVAW8S's Avatar
There is a sync button in the Pivi Pro. Click on the climate button and you will see the rear climate button. there you can click on sync for the second row.
Old 02-03-2021, 11:41 AM
PaulLR's Avatar
Thanks!. I was just about to go find the answer in the owners manual.
Quick Reply: rear climate not working
