Rear Molle Plate
Rear Molle Plate
Happy with my new molle plate from @PowerfulUK Plate is really solid and neat.
One minor snafu with one of the clips at install but no big deal.
Will be great to have somewhere to store all those moles.
Without a clearsight mirror I'm not sure I'd install this.
Lower middle bracket needed to be drilled out to get the hex bolt in. Too tight a fit.
Lower middle bracket also cracked with the self tapping screw I used. They don't supply one so drill the hole plenty wide in the clip.
Jbiggzs (10-03-2023)
GrouseK9 (10-05-2023)
CA Law(a)(1) A person shall not drive any motor vehicle with any object or material placed, displayed, installed, affixed, or applied upon the windshield or side or rear windows.
(b) This section does not apply to any of the following:
The rear window or windows, if the motor vehicle is equipped with outside mirrors on both the left- and right-hand sides of the vehicle that are so located as to reflect to the driver a view of the highway through each mirror for a distance of at least 200 feet to the rear of the vehicle.
