Roof Rails on V8 Model Defenders?
Anyone know why Land Rover wouldn't be offering roof rails on the Defender 90 or 110 if ordered as a V8 model? I cannot imagine the roof is any different. Could the rails be added after the fact? A source to purchase these? The dealer was not helpful. To be clear, wondering about the rails, not the racks. Planning to a 90 V8 in the next couple weeks, this is just frustrating us!
Thanks! |
Originally Posted by machspeed
(Post 775988)
Thanks! |
(Post 775988)
Thanks! Not sure why that is, or if it's specific to the roof itself or just a general hauling weight limit and it's a way they are trying to lower it. I know there's limits around the weight the air suspension can support so even though I can tow 8000 pounds it's very difficult to tow a where close to that with the weight that gets put on the rear suspension. I assume the V8 weighs more. Regardless I would suggest not putting anything on the roof of the V8 - a company usually doesn't want to not sell you accessories so there's gotta be a good reason for it. |
Look online I just got my V8 110 and installed the roof rails, no issues at all. Your dealer may not want to sell them so you may need to look around.
Originally Posted by Pdm.ao2
(Post 859750)
OEM rails, just make sure that you install the rack with the proper manufacturing suggested torque settings and you will also need a security five star tool to remove the existing bolts. The insulation is simple.
2023 Defender 110 V8
Originally Posted by jimshadow
(Post 863497)
OEM or Aftermarket? If the latter, which did you go with?
Thank you for sharing. |
Hi, I initially ordered the OEM version, after seeing it and installing it on my roof, I did not like it nor did it meet my needs. Then I say the BA one (Badass Tents company) they have one with single bar int he front and 3 bars in the back (https://badasstents.com/product/2020...ts-90-110-130/) it is pretty sweet but I need more to install an Awning, and other accessories (Paddle boards, Tent, Skis etc. it looks good but worried not enough possibilities. I called them up the said I could return if I did not like but it is a ton of work. Right now I am looking at the Slimline II, and Thule can out with a new rack that looks great but have not been able to source. I have to make a decision this week as I need one badly. I will let you know what I will get.
Originally Posted by DDavidson
(Post 864316)
Would you be kind enough to tell me what mfg you purchased your roof rack from and share with us a few pics. I have looked everywhere for a rack for my 110 V8 that i just got. I need one that works badly.
Static weight
I find it interesting that the static load weight for the p400 and p525 are the same at approx 661 lbs. what makes the dynamic load on the v8s drop to 0? If the roof can support the weight at a standstill then the V8s are built the same. It must be a power or an acceleration issue ? Any insight?
