Spare tire cover rubs against wheel
So I was putting the 22” wheels back on for the summer and removed the spare tire cover. Noticed that it rubbed against the spare wheel and scuffed them up pretty good. Attached a pic of what rubbed against the wheel all winter.
Has anyone else experienced similar? Is my cover missing any felt/foam padding that would normally prevent this?
So, interesting. The spare tire cover I got doesn't have that contraption inside (that looks like it keeps it centered on lugs)... just a bit of foam (like a foam block) between the outer cover and the wheel.
That said I took it off and it's in the attic because I didn't like the look.
Do you have pics of the front side? This is just the standard "DEFENDER" spare cover yes?
Yeah, I don’t love the look either, but left it on for winter since the spare didn’t match my winter wheels.
It’s the standard cover but the newer version that’s gloss black on the top/bottom and body coloured in the middle. I didn’t know they were different on the underside.. I’m gonna have to find some type of foam/felt to put on if I wanna use this again next winter
Interesting. I have the same wheel cover without the foam and I was worried about the plastic against the wheel. I'm going to try adding some padding foam on the inside of the cover to stop it from rubbing against the wheel: https://a.co/d/doDix1m
wfwalton (11-18-2023)
