Stock ladder vs. Lucky8 Proud Rhino?
(context: doing build homework)
Proud Rhino looks like it has the same utility as the stock, but doesn't stick out as a sore thumb, doesn't add drag, and won't catch as many branches. The only upside to the standard ladder that I see from my point of zero experience with the vehicle is the fact that there are aftermarket contraptions to hold RotopaX containers, but then again, they can be mounted to the spare tire otherwise.
Any other non-obvious advantages the stock ladder has?
PS: Just found this video:
- at about 32:00 they show how the ladder rattles in the closed position, however, later they mention that they forgot to install a piece, but say nothing about whether that missing piece removed the rattle. Does it? Or the stock ladder is that loose?
The following 5 users liked this post by wcc18999:
DeadEndMike (08-30-2023),
DonMitsu (02-21-2023),
ficklma1 (01-17-2023),
Huc (01-18-2023),
this_account_is_mt (01-17-2023)
A big advantage for me in having a side ladder is that it allows me to reach far more of the rack when I'm stood on the ladder itself. A rear ladder would not confer this advantage. Useful when arranging skis and poles, digging things out of roof boxes, removing recovery boards etc.
I use the ladder at least once or twice a week. I'm a big fan of its design and usefulness.
On drag. I'm no aerodynamicist but don't notice any buffeting noises from that area. I suspect (generous pinch of salt here), that given the tapered shape of the Defender (fatter to the front) it sits in the lee of the Defender's fridge-shaped front end.
As others have said. No rattle in it whatsoever.
The following 5 users liked this post by GavinC:
Craig_RRS2013 (01-17-2023),
drcoop (01-16-2023),
nashvegas (01-16-2023),
Vadiable Paradox (01-16-2023)
Industrial design cohesiveness!
The stock ladder shares the same modern minimalist elegant design language throughout the defender. Many of the aftermarket ladders and roof racks and such are traditionalistic, rugged and nostalgic which in terms of design are actually not cohesive with the rest of the vehicle.
Defendit.. (01-16-2023)
Style is a very personal choice. Some like the looks of the OEM better than the Lucky8/Rhino, some the other way. I went old school and purchased the rear version. It is true that you lose one of the PowerfulUK reverse light mounting points. I was VERY bummed about that because I loved the reverse upgrades. They should have been what JLR had installed. But, I've since installed rear lights for when Overlanding and they are BRIGHT. Now, no more problems! Here's my thread on the lights (Link) and my thread on the ladder (Link). I have since replaced my redneck step with the version from PowerfulUk (Link). Their standard is a right hand step, but if you tell them - they will make it for the left. It works very well and can quickly be taken off when needed. When off-roading, I sometimes just take it off ahead of time.
These links go into both items with a lot of info from others, so hopefully you find something in there to help. Good luck.
What the designers at JLR thinking were modernism, elegance, innovation and sophistication. You are of course entitled to your opinions and feelings and that's also the reason why there are companies that make "old school rugged" type of accessories for folks that share your view.
While I wish the side ladder was all black, I think it looks nice for what it is and fits better with the aesthetic of the new Defender, as opposed to the rear mount ladder approach. Just my opinion though, and you know how that goes.
