Tire Pressure for defender L663
https://landroverforums.com/forum/20...itions-102323/
I pulled this thread up from our past discussions, which will address your questions.
pressure
i have k02’s LT and my tire shop put 50 psi. i know the tires can handle it but it’s a rough ride. what’s the lowest i can go only daily driving
If your shop recommends 50 PSI, they probably know something you don't (I suspect they are in the ballpark.) To make absolutely sure, call BFG customer support and tell them what you are doing: the vehicle you installed their KO2s on, what the original P-metric XL tire size is and what Land Rover recommends for light and normal loads, front and rear. They will calculate the equivalent load capacity and PSI to use with your LT tires. You may be surprised at the numbers they give you and may find the ride does indeed become harsher - it's the inevitable byproduct of switching to much heavier, stiffer and stronger LT tires. Decreased gas mileage is another.
This tire pressure calculator is very rudimentary and unfortunately only covers a small portion of popular tire sizes, but should give you a pretty good idea about the difference between P and LT tires PSI.
https://tiresize.com/pressure-calculator/
Tire pressure related question
I did lower mine to 49 rear and 47 front from door jam label and used a new -what I believe is a good mechanical gage. My system on the Defender tells me to use the pressures I have e.g. recommended. But my system readout of actual pressure is lower than my mechanical gage. Anyone else notice this? I am stock everything on P300 with the Pirelli Scorpion All Seasons. They seem ok in snow and ice so far with limited driving in those conditions BTW.
