TPMS programming
Just a quick update.
They started working after being driven a few times before I had a chance to take it to the tire shop. I guess I just didn’t run them long enough, although it may be partially due to the nut behind tbe wheel.
I’m not sure what made me check as the low tire light was still on but I checked and they were reporting that the tires were at ~30psi so they were low even as I waited for them to fire up so I don’t know how quickly they started to work. Anyways, they’ve been back to proper pressure for 4 days and they’re working perfectly. Thanks for all the comments, hopefully they’ll help me or someone in the future
I am Wondering because I bought a set of Tire Rack ones, but my tire guy is telling me they will need to be programmed with an OBDI; which would mean I need to actually drive the Defender to his shop, which I am trying to avoid due to some logistical constraints. I am hoping to just take wheels to him without driving vehicle.
Do you mean the Tire Rack ones can be taken out of the box, installed on the wheel, and they will literally sync to the vehicle (Defender) without any programming required?
Dealer wanted to sell me a set of LR ones for over $800 plus install with a 5 week lead time.
Discount tire grabbed 5 from a box off the shelf for about $35 a piece. Synced them/cloned them to the car once the new wheels and tires were on it in about 5 minutes.
Amazon option work too. You don't need anything fancy. TPMS is almost universal it seems.
Any of them work fine. I have a set of 5 on my aftermarket rims.
Thanks for the reply Gavin, but didn’t really address the specific question. A previous poster said the Tire Rack ones apparently didn’t need to be programmed to vehicle - they just worked/synced out of the box. I’m trying to confirm this so I don’t have to drive me Defender to the tire shop (I just want to take my wheels in).
My poorly made point was that, Discount, Tirerack, Amazon, Tires-R-Us, Jiffytire it matters not. The TPMS is all one and the same for the Defender. They all need to speak to the car's computer. A digital handshake to say, yep, we're the droids you've been looking for. This required some tech whizzbang using a hand held device for my set.
Given that the TPMS are all the same (once you buy the right kind), I assumed this programming is a universal requirement. Apologies if this is bad intel.
The tpms should auto program. If you put a new set on the car it might take it a couple of drives to register and self program. But that's how it works. It shouldn't need any manual programming
Sometimes the TPMS need to be activated when new with a 'wand' to start them operating. But you don't need the car for that
If anyone is claiming they are 'programming' then I'd ask them if you can watch...
longtrip68 (04-12-2024)
I watched him do it. Very simple stuff.
Yeah, the tire shop said I had to bring the vehicle in so they could program it with thru the OBDI. I’m suspicious. I’m gonna mention your suggestion to them (that is, just wake them up).
