Trunk door doesn't open properly
Hi there. Got my LR Defender 23.5MY a week ago. All worked great, then the car went to the detailing for film appliance. Today got it back and there is a small issue, trunk door doesn't open properly any more. When button is pressed, the lock makes the noise and the lock kinda opens (door moves towards you), but if you pull the door it doesn't go there, like it is still held by the lock. I am sure that it worked ok before. And also sure that the door was not disassembled and all gaps and the hinges are still at the same place they were before.
Any ideas what could it be?
wlindsey@gmail.com (02-13-2024)
Went to the dealer today, they checked everything and told its because of the PPF (film). The door rubber sits so tide to the body of the car that when it goes against the PPF edge, the lock feels the resistance and blocks the opening (the perimeter of the edge is so big that resistance is huge). So I went to the PPF installer straight away and they cut the PPF (made it shorter), so the door rubber is not in contact with PPF any more. And everything started to work as should. So problem solved.
Mine has started to do this, especially when I go up to the slopes for skiing. No special film on mine, just a bone stock door as it came from the factory. It is obviously the soft close mechanism catching and re-closing, you can hear it. Kind of annoying, particularly with another item that is kind of in the category of "uh-huh, it does what?" Now it is in the category of useless POS that made the car cost more. On the list for my next service call. Luckily the SME mining conference is in 10 days in Phoenix so I can drop it off then.
