Vehicle height to top of roof rails
The numbers I keep seeing online for height in air suspension setting is 77.4-77.5 inches. I believe this is measured to the satellite antenna, which is the tallest point. The height to the roof rails should be just a little shorter. Access height should be about 2" lower and off-road height should be about 3" higher.
I was looking at heights when I was considering adding an expedition rack to see if it would fit in the parking garages I use regularly.
Thanks guys, I have tall ceilings 14 1/2 ft in my garage and have a 4 post lift installed so that I can park my Shelby GT 350 above during winter so the clearance under my lift when it is setting in the upper locks is 80”. So as long as I don’t come in with the suspension in the off road position I’m OK….otherwise I will have the first convertible..Ha Ha
The vehicle also shows you on the display screen the exact height at the different levels - it appears to be quite accurate.
![](https://www.autoguide.com/blog/wp-content/uploads/2021/11/2021-Land-Rover-Defender-90-Review-HZ-19.jpg)
