Wheel Arch install (dealership)
also, you fender most likely will start lifting. if you don’t fix it before it starts lifting you should bring it back in when it does. it will be evident that it wasn’t installed correctly
beside some messy double sided tape clean up you can tackle the re-install. just pick up some 3m moulding tape on amazon. need prob one roll. it’s 10 bucks. it’s better for you to remove the tape as early as possible before it sets and has a strong bond. if you ever messed with removing double sided tape it’s time consuming and your fingers will be sore after.
you prob need some extra clips as they are one time use
@Ehloo is giving great advice. I would recommend ordering a package of these first: https://www.powerfuluk.com/vehicles/...nder-2020.html. Some have had success with other versions, that's up to you. Personally, I'd place the order and then when they came in (usually ~5 days) I'd do what @Ehloo recommends. At the same time order the 3m tape from Amazon. It is HARD as "crap" to peel off the red protective cover, but that just leaves me with the impression that it will hold "just right". It's a quick job to fix. Likely your biggest PITA will be removing the trim tape from the extensions. Someone else will have better advice on the best way to remove it. I would just do the whole deed before it got hot or cured for too long.
