Florida Rover's 1997 Discovery XD
#21
While my Florida Land Rover Club buddies were at the spring rally, I set out to address a "clunk" noise that occured when turning side to side
Roof rack removed, cleaned and prepped for surgery
I had no history on the wheel bearings so they were first on my list
Going in
Come to find out the passenger side CV splines and drive flange were extremely worn (will add pic)
Both half shafts and driver's side CV looked good
Sitting, waiting for parts
Went with a set of used CV axles and drive flanges from Paul Grant
I also decided to rebuild the swivel ***** since I was in this far
Fender removed for snorkel install
Inner seal was leaking
Bench reset for the rebuild
Going in
#22
Took a chance on the Britpart kit from Lucky 8
Teflon ***** were in great condition
Bottom race was easy enough
This one required some effort
No more grey diff oill
Painted the housing & stub axle
Salvaging my worn CV to seat the bearing
Pressing it past the thrust ring
Assembled with preload set
Installed
Shiny
Bearings were next
Went with the RTC3511 per the consensus
Driver's side complete!
Installed
Shiny
Bearings were next
mr4x4 (08-13-2017)
#23
FloridaRover (05-07-2017)
#24
After doing the driver's side this one me took 1/2 as long
Clever trick for these bolts, 12pt ratcheting Gearwrench is key
Down
Clean and waiting
Keeping the old parts close by
Driving out the races
Pretty much a pro at this point
Backyard spray booth
Rustoleoum gloss black
Home stretch
My "new" CV in much better condition
Fresh bearings
Job done
Down
Clean and waiting
Home stretch
Fresh bearings
Job done
#25
#27
Apparently some people leave that seal out and allow the gear oil to lubricate the swivel ***** / bearings but I chose to rebuild according to spec
WaltNYC (05-09-2017)
#28
If the truck was all original when I got it then I wouldn't dream of hacking it up (not that I could afford to)
But since it was already used and abused I figured just keeping it running and on the trail was doing her justice.
#29
#30
During the front end service I mocked up the used Mantec I got from Joe!
Found the template online somewhere, possibly DiscoWeb?
After a few progressive cuts I got a nice shape
I also swapped out a rusty wheel with one of the donor rims
Obviously I couldn't install my new snorkel over this faded A pillar
And fishEh inspired me to paint my inner fenders sooo....
Taped up
Refreshed A Pillar
Mud / water protection
Which led to treating the rust below the brake master
Enhance
Treated
From below
Prepped
Apparently I didn't take pics after painting the wheel well so will update later...
Taped up
Refreshed A Pillar
Enhance
Treated
From below
Prepped
