My 2000 Discovery 2 SD camping build
https://cimg6.ibsrv.net/gimg/landrov...79504046aa.jpg
This is how I first got it in early October 2025. $1400 and non running, but overall in decent shape with no rust https://cimg0.ibsrv.net/gimg/landrov...34ce000b14.jpg This is how it sits now a few weeks later. New crankshaft position sensor, new ECU and BCU, and new upper windshield finisher and it runs and should hopefully leak a bit less. https://cimg8.ibsrv.net/gimg/landrov...f8e4bf0b8f.jpg New BFG KO3 tires in 265/75/r16. There's a tiny bit of rubbing, but the planned lift will fix that. |
Very nice! My first Dll was a SD 2001. Which was nice, had locking CDL...just needed to add the mechanism to engage. Loved the no sunroof, too...no leaks. Still have a soft spot in my heart for that 01. Now, the two 03's and one 04 we had...was more of a soft spot in my head from beating it against the wall sometimes...lol. No, actually...only one gave me grief.
My 01 build. She was a beast...with the M/T's, CDL and Traction Control. https://cimg7.ibsrv.net/gimg/landrov...b8120768fe.jpg https://cimg3.ibsrv.net/gimg/landrov...bdb77ab1e7.jpg https://cimg6.ibsrv.net/gimg/landrov...76826c97fb.jpg Looking forward to following along on your build. |
Looks cool! What are the plans?
(Post 938622)
Originally Posted by longtallsally
(Post 938760)
I wouldn’t do either the electric fan or in line t stat until you find good OEM stuff isn’t sufficient. On every D2 I’ve owned, a new (and perhaps a bit more aggressive) fan clutch, soft spring 180F OEM t stat, new radiator, flowkooler water pump, and then 50/50 green stuff with some Water Wetter has allowed me to drive all through the mountains at freeway speeds- a good number of times towing- and rarely if ever go over 200F. I run both AC units as well. I’d make sure your condenser fan is working too.
If you are hooked, splurge for a Nanocom as they are invaluable in diagnosing. I’m sure you know, but the Ultragauge or other means of monitoring temps are critical and will kinda prove what I was saying about temps. I’ve said once you catch up on the needed service, and address some OEM flaws, a D2 can be just as reliable as anything else on the road. |
(Post 938766)
Originally Posted by bripark3
(Post 938769)
Going stock might save me some money so that's not a bad idea. I just need to make sure it can function in high temperatures since summers are often above 100F for long stretches. For radiators do you stick to OEM? A NanoCom and ultragauge are on the list for sure.
We see triple digits a good bit over the summer and I’m at elevation if that helps at all. Commuting over the summer I’d hit just over 200F going uphill at around 7k feet and 75+ mph. The Ultragauge is a hard requirement before you drive it at all as they overheat very quickly if everything isn’t sorted in the cooling system. Also, assuming you run AC a lot, making sure the condenser fan works is key. This is where the Nanocom can help verify and such. You downloaded the Rave too, yes? |
(Post 938781)
I’ve always used Nissens and had good results, but I’ve read a few reports of them not being so great recently. The key is a new one and a well flushed system.
https://cimg6.ibsrv.net/gimg/landrov...b659ca5f6a.jpg
https://cimg7.ibsrv.net/gimg/landrov...7892879725.jpg Got some new stuff in today. The boss head unit is pretty nice though the screen is a lot bigger than I expected. It's good to be able to ditch the cassette adapter and this is something I've been wanting to do to both my other discos, but never had a chance to. I'll have to figure out a better way to organize the cables, but I'm a bit under the weather and wasn't feeling up to it. I also put in a new air filter, pollen filter, and intake tube to replace the crumbling garbage that was previously there. I also got in some brakes and filters for the engine and transmission which I'll be replacing once I'm feeling up to it. |
| All times are GMT -5. The time now is 09:12 AM. |
