2.5 NA Diesel engine mounts replacement Problem
HI there
Im currently working on replacing the engine mounts on my LR 110 with 2.5 NA diesel engine . I managed to replaced the Right side engine mount , but now Im having problems removing the Left side. Unfortunately a socket or wrench would not fit to remove the top engine bracket bolt the Lower bracket bolt is also hard to remove. I been tried lifting the engine on the left side and no success getting the engine mount loose. How much can I lift the engine? Any advise? https://cimg4.ibsrv.net/gimg/landrov...5f23fdb781.jpg |
You can lift engine high enough to remove motor mount, then you'll have accees to bracket bolts.
