Defender Talk about the Land Rover Defender within.
2009 Defender dies after 20 minutes
Old Jan 14, 2026 | 06:26 PM
LandyLimey's Avatar
3rd Gear
Default 2009 Defender dies after 20 minutes
Ok, we have a 2009 Defender with the 2.4 Puma diesel.
It starts just fine, then runs great for 20 minutes before fizzling out, llike there is a fuel issue. It is drivable at walking pace with no power after this. The mechanic replaced all the injectors, the fuel filter, and cleaned out the fuel tank, but it still happens. There are no codes apparently. Has approximately 100k miles, has been regularly serviced with OEM filters and parts.
Any ideas what this may be?
TIA!
Old Jan 24, 2026 | 04:19 AM
The Deputy's Avatar
This gentleman had a similar issue.
https://www.defender2.net/forum/topic96098.html
Not many Puma engine Defenders here in the states. But, after a quick search...found two or three topics that mentioned battery, charging system or ECM corrosion at terminals...might cause this issue. Good luck!
mdawodi
Apr 20, 2024 05:42 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
welling4x4
Sep 29, 2010 11:05 AM
Mountainman
Nov 12, 2007 09:59 AM
plutonic2
Jan 27, 2005 08:58 AM
