2004 Discovery - Steering Wheel options
Hi all, my 2004 Discovery is tan leather interior which means that everything can be seen. The dealer did a good job detailing the car but the steering wheel leaves something to be desired. The leather has ripped off/torn off in a few places.
Can the leather be replaced/repaired in small places? What are the options to replace all the leather on the steering wheel? How much does replacing the leather cost? Can you put in a new steering wheel? How much does putting a new one in cost? Thanks!! |
Check out roverlandparts.com. I have the same color interior and do not care for the two-tone steering wheel. I am ordering a black one; $195.
If you want to get a tan/black wheel they have those too. I have an independent Land Rover shop in Cleveland that will do the job. Good Luck! Any idea as to how to fix the coin and ash trays? Mine do not come back out like they should. I looked inside and saw a spring but am not sure how to fix that. |
Originally Posted by lmalbright
(Post 337666)
If you want to get a tan/black wheel they have those too. I have an independent Land Rover shop in Cleveland that will do the job. Good Luck! Any idea as to how to fix the coin and ash trays? Mine do not come back out like they should. I looked inside and saw a spring but am not sure how to fix that. I have this problem with my coin tray, and my back cup holders lost a spring as well. |
I had the same problem with my first Discovery. Bought one from the dealer. Easy to replace. The whole unit pops out. You may want to check with roverlandparts.com. A used one will be much less thru them.
(Post 337666)
If you want to get a tan/black wheel they have those too. I have an independent Land Rover shop in Cleveland that will do the job. Good Luck! Any idea as to how to fix the coin and ash trays? Mine do not come back out like they should. I looked inside and saw a spring but am not sure how to fix that. https://landroverforums.com/forum/di...de-pics-43588/ I printed these instructions out as my wife's D2 is stuck also. I haven't done it yet, hopefully I'll get to it this weekend. |
