Your Ash ray and Coin Tray Stuck? Look Here. Fix Write up in side with Pics!
Old Sep 8, 2011 | 01:06 AM
sickws6's Avatar
Default Your Ash Tray and Coin Tray Stuck? Look Here. Fix Write up in side with Pics!
Not sure if this is the right section. I just bought this 04 disco last night and found out that my trays would not retract back out it got pissed me off so I decided to fix them.
I started by taking the trays out by pushing on the tab to be able to pull the tray out shown below:
After I got the trays out there are 3 phillip head screws on both sides behind where the trays fit. Take those screws out and the complete housing will come off.:
After the housing is out you will discover (lol) that the spring retainers on the plastic housing will be broke off. Just grab a couple small but stron zip ties and use 2 on both springs to hold the spring tab in place tight against the housing. Tread the tie between the small opening that the spring arm itself goes through and through the broken opening of the housing. pull the ties tight to hold the spring tab tight:
And a video of how the trays should function:
VID00012-20110908-0130.mp4 video by sickws6 - Photobucket
Old Sep 8, 2011 | 05:25 AM
Youthful ingenuity trumps British engineering!
Old Sep 8, 2011 | 09:08 AM
0304Disco's Avatar
Smile
Wow!!!! I've had a broken coin try forever and it has never made it on my list to fix as I have many other issues to battle.
This looks like an easy fix so I will give it a try today.
Thanks for the very nice write up
Old Sep 8, 2011 | 02:07 PM
Pacerlive's Avatar
I could really use a Ash Ray...
Old Sep 8, 2011 | 02:42 PM
DeepBlueWater's Avatar
Thanks for the how to!
Mine's been broken and stuck slightly open so long I forgot that it retracted flush...
Applauds,
Michael
Old Sep 8, 2011 | 04:18 PM
russburcham's Avatar
GREAT! Did the job today on BOTH! Only difference with my '01 was that i needed to remove all 6 screws then had to pull out both trays AND cup holder assemby, as it was ONE single unit... THANKS much for the write up!
Old Sep 8, 2011 | 05:18 PM
sickws6's Avatar
I am glad the write up helps. Thanks for the comments!
Old Sep 8, 2011 | 10:07 PM
amccullough's Avatar
Nice! This should go in the write-ups section!
Old Sep 10, 2011 | 11:00 AM
sickws6's Avatar
thanks guys, I did not know if there was an interior section but I think it would be a good idea for easy reference. I bet a lot of peoples LR trays are broke.
Old Jan 6, 2012 | 08:02 PM
Texarican's Avatar
Thank you thank you thank you! This was a 10 minute fix that I just did tonight. So cool
