Optimum Metal Polish
If it is meant to shine, make it shine. Optimum Metal Polish is a really easy to use product that cleans and protects your metal surfaces. Applying it by hand or machine, the results will be the same; your metal trim will have the brilliant shine that caught your eye when you first got your truck. It leaves behind a clear protective coating to keep it shining longer.
Application
Apply to applicator, in this case finger pocket. Depending on the surface you can use a wheel ball, pad, or even a cloth.
Use a quick circular motion to work the cleaners into the metal.
Wipe away with a soft microfiber towel.
Take a look at the results.
Application
