1993 Landrover discovery
Ok, you have a '93 DI. What engine does it have, a petrol or diesel? The petrol uses RTC5680 while the 200TDi uses RTC5681. I don't have much experience with the diesel version but if you have a petrol engine you could use a RRC alternator. I'm not sure if you're in the US but it appears as though it's a 65 amp alternator so if you're here in the US you could use the 1987-88 RRC part as a crossover.
And then they get frustrated when no one gives an answer.
But for looking at the member profile (which I normally never waste time to do) I wouldn't have seen the AU Country code.
