1995 Land Rover Discovery hasn't started in years.
Hi guys im new to this form but I have a 1995 land Rover Discovery 3.9L V8i Automatice tranny with a new battery. Its current state is not running and will not take electric power such as no dome lights when I open the door no horn when i press it, except for a dimly lit clock that goes dark when i try and turn the key or turn on a light. I did check and replace fuses under the hood checked all the smaller ones also all seem good to go if anyone can help its would be greatly appreciated.
I also posted a video on you tube so you can get a visual of what im saying.
You said the battery was new a month and a half ago, has it been connected the entire time? It's probably drained low enough not to start or power the D1 now, I'd slap it on a charger. If the battery is okay then I would clean the battery terminals, and all grounds.
Rover's are known for having corrosion collect on the grounds over time especially on rigs that are just sitting around.
BAD contact at battery, rechech frame and body ground unbolt clean rebolt, check power cable at starter be sure its tight ( with battery unhooked of corse) do you have 12 volts at the fuse box under hood? fuse box under dash?
did mice get in and chew the dash wiring? guy here with an lr3 mice/rats destroyed his harness from it sitting
hell try adding a ground go from batt to engine see if it changes use a jumper cable if need be
