1997 Discovery XD can't maintain idle
Old Jan 27, 2021 | 05:30 PM
hriant88's Avatar
Default 1997 Discovery XD can't maintain idle
My 1997 Discovery XD suddenly can't maintain idle. It was running fine before except got some bad exhaust leaking (exhaust pipe has a hole before muffler and possible bad cat). Then today, the car started but hard to maintain idle. If I kept pumping gas it would still run but rough with less power. At the stop, the idle is low and goes up and down.
Could this be a cat problem? or anything related to it or the O2 sensors?
Old Jan 27, 2021 | 05:31 PM
Best4x4's Avatar
Check the IAC Stepper motor.
Old Jan 27, 2021 | 06:53 PM
hriant88's Avatar
What is the IAC Stepper motor? Where to locate it? and how to check?
Thanks!
Old Jan 27, 2021 | 07:09 PM
Best4x4's Avatar
located on the Throttle Body Assembly mounted facing toward the radiator. Black round unit held on by 2 small bolts. Has one electrical connector. When the IAC gets dirty it can stick and cause a rough idle or if it dies = stays in one place causing a rough idle. Any check engine light?
Old Jan 27, 2021 | 09:48 PM
hriant88's Avatar
no check engine lights. my one is a 1997 Discovery 1 Camel Trophy Edition,
Old Jan 28, 2021 | 12:08 PM
WaltNYC's Avatar
new IACV from Napa (PART # :CRB 21856). check engine light will not necessarily illuminate.
Old Oct 11, 2021 | 07:24 PM
hriant88's Avatar
Changed to a new IACV and thoroughly clean the throttle area but it didn't help. The problem stays the same. starts up cold no problem, idles at 750-800 and it drops to below 500 after 10 or 15 minutes ride and then I have to give a bit gas to keep the car running at the stop.
anything else could be contributing to this problem?
Old Oct 11, 2021 | 08:27 PM
ononomos's Avatar
A bad fuel pump will cause that.
Old Oct 11, 2021 | 08:53 PM
robertf's Avatar
maybe a long shot, but check the wiring for the crankshaft position sensor. I'm 4 for 4 on trucks that needed this repaired.
usually doesn't show up until a car wash or heavy rain, but idle goes to crap
Old Oct 11, 2021 | 08:58 PM
robertf's Avatar
Just to be clear, is it an XD or camel trophy edition? the camel edition that you could actually buy new at a dealer had a distributor and wasn't sold in North America. There are lots of things that could go wrong with the distributor that can cause idle problems. It would have used a different idle air control than the one listed above so its easy to rule that one out.
