1998 d1
Old Sep 2, 2021 | 05:03 PM
Jar9148red's Avatar
4wd High
Default 1998 d1
Any tips on changing out the Camshaft position sensor? From what I've read the symptoms match mine just about perfectly.
Old Sep 2, 2021 | 06:21 PM
disco96sd's Avatar
camshaft position sensor is usually the last sensor to need replacement - what are the symptoms ?
VSS and Crankshaft sensor are the usual suspects
Old Sep 2, 2021 | 09:40 PM
Jar9148red's Avatar
4wd High
I've realized that most people online refer to is as crankshaft position sensor instead of camshaft position sensor, so it is the crank position sensor that is going to be replaced. But the symptoms are only starting when it's cold, misfires, stalling at idle, and lowered power.
Old Sep 2, 2021 | 10:34 PM
disco96sd's Avatar
get the Lucas brand
RBSDISCO
May 21, 2019 08:31 PM
Volt
May 3, 2018 07:21 AM
FantomRover
Dec 16, 2013 12:31 PM
DiscoIIBrandon
Nov 30, 2010 01:20 PM
joverrover
Jun 27, 2007 11:42 AM
