94 Disco, will not start
Battery was good to go and recharged today for good measure...i'm thinking relay by the clicks i am doing. Not even getting a click from the solenoid, it is all coming from behind the glovebox
Check the wiring.. Sounds like a ground has gone bad..
I worked on one of my cars for three days.. Replaced the starter and finally figured out the negative battery cable was bad...
Measure the voltage at the battery.. Turn the key to start.. Voltage should drop a little while cranking.. If no crank and no voltage drop, Then you need to check the + side of the solenoid for voltage...
You should be able to jump from battery + to solenoid + and get the engine to crank if nothing else.. If that doesn't happen. You've got a bad cable somewhere..
If you get a big voltage drop and no crank. Bad battery..
Good Luck
John
Good Luck
John
Good Luck
John
Good Luck
John
I'm going back outside now, I'm going to check everything again, anywhere and anything i can get a reading from I'm checking it.
Have you checked your ignition switch lately? Very easy to do on a 94. Once removed try giving it a crank with a small flat blade screw driver and give it a wiggle while twisting. I'd bet a buck it's contacts are Lucas-fried.
In the ETM for the 95 there is a great troubleshooting flow chart and it starts with the starter solenoid relay.....which is what your hearing click. Yellow relay right next to and behind the green relay on bottom ledge of relays. It's behind RH kick panel. Good luck eh.
As far as I'm aware of what you've checked and done and what hasn't been checked it's either the ignition switch, solenoid relay or the alarm unit breaking the ground connection between the ignition switch and the starter bendix.
The Rave (at least my copy, there are a few) shows how to check the relay pins by number. This is in the Starting/Charging section of the ETM - Electrical Troubleshooting Manuals.
The sad part of the problem is it can be one of several things. Again, isolation is the only way to find out. Using the ETM will help a ton by following the wiring diagrams. Pretty darn easy.
Well, got the wiring starting issue sorted out....sort of. Thanks to everyone's help and replies. The issue ended up being a corroded starter ignition relay wire and ground strap that connects to the starter. The starter ground strap had corroded at the ground location and the starter ignition relay wire that plugs into the bladed connection had corroded back near the rear of the motor. I crimped a new section onto it and then crimped a new connection to where it connects to the starter. Now for the fun part.......................
I turned the key it was sluggish at first and then it appears/sounds like the bendix is not engaging the flywheel. I have hooked up jumper cables to help recharge the battery tapped with a rubber hammer trying to free it. It spins strongly but it is not engaging. I am assuming the best order of business next is to remove the starter and re-installing it and see if that helps along with recharging the new battery....again
