96 body electrical control module??
I own a 96 disco se7 with a 5 speed recently the srs light came on, the abs light came on (and quit functioning), the cruise doesn't set, and the head lights are sparadically dim (some times drivers some times passengers never both at same time). none of the above are consistent (except for the cruise not working). Also the rear windows dont function and the front power seats and cigar lighter have quit working. which led me to believe it would be the body electrical control module. However roverland told me that I don't have a BeCM. Where do I start? Is there a fuse box in the engine compartment that may have started to fail? Is the box under the passenger side dash with the 2 plugs the ECU? I need help!!!!! To bad there isn't a scared icon.
There is a fuse box under the hood. Start looking at grounds. The SRS is usually a good indication of a low voltage situation. Turn on your headlights and start jiggling wires. Start under the hood and work your way to the passenger side under the dash. Yes, your ECU is there.
ECU vs. BECM
Originally Posted by okdiscoguy
(Post 107864)
On a D1 there is no BECM or BCU. There is a window ECU under the dash. You can download the RAVE shop and electrical manual set for free below.
Dealer diagnosis
(Post 337131)
The Window ecu is behind the glovebox. The rear windows not working is a bad solder joint inside the window ecu. Drop the glovebox completely down, remove the card edge connector,grasp the circuit board with needle nose pliers and yank it straight backwards to remove, reflow solder joints and put it back in. Reconnect plug and test windows.
Common problem on DI's. Paypal your appreciation to dannyleebullseye@hotmail.com |
I suspect that we are both right, the tech calls any module a body control module; and the windows do have their own ECU, but it just does the windows. Cold solder joint in it will make things not work.
