96 body electrical control module??
Old Mar 18, 2009 | 10:39 AM
joshuaaa316's Avatar
4th Gear
Question 96 body electrical control module??
I own a 96 disco se7 with a 5 speed recently the srs light came on, the abs light came on (and quit functioning), the cruise doesn't set, and the head lights are sparadically dim (some times drivers some times passengers never both at same time). none of the above are consistent (except for the cruise not working). Also the rear windows dont function and the front power seats and cigar lighter have quit working. which led me to believe it would be the body electrical control module. However roverland told me that I don't have a BeCM. Where do I start? Is there a fuse box in the engine compartment that may have started to fail? Is the box under the passenger side dash with the 2 plugs the ECU? I need help!!!!! To bad there isn't a scared icon.
Old Mar 18, 2009 | 01:51 PM
okdiscoguy's Avatar
There is a fuse box under the hood. Start looking at grounds. The SRS is usually a good indication of a low voltage situation. Turn on your headlights and start jiggling wires. Start under the hood and work your way to the passenger side under the dash. Yes, your ECU is there.
Old Aug 11, 2012 | 02:47 PM
unpolire's Avatar
4wd High
Default ECU vs. BECM
I have a 1996 Discovery SE7 (USA automatic) and my ECU is underhood, shielded against the inner fender. Is the ECU in the dash area a BECM? Mine was diagnosed by the dealer as having a ground fault, resulting in sporadic operation of my rear windows. Would like to know the correct location of the unit.
Old Aug 11, 2012 | 06:10 PM
On a D1 there is no BECM or BCU. There is a window ECU under the dash. You can download the RAVE shop and electrical manual set for free below.
Old Aug 13, 2012 | 07:12 AM
unpolire's Avatar
4wd High
Default Dealer diagnosis
This makes trips to my local Land Rover dealer a scary proposition, after paying them thousands for parts and repairs on my Range Rovers and Discoverys. They wanted to replace the "Body Control Module" to repair the intermittent rear window function. Claimed to have traced the problem from the underhood fuse box directly to the "BCM," and found a ground fault in the unit Nearly $200 parts and labor additional to replace. Maybe the techs just call all controls for windows, etc., BCMs, like on later model year Land Rover vehicles?
Old Aug 13, 2012 | 09:34 AM
Danny Lee 97 Disco's Avatar
The Window ecu is behind the glovebox. The rear windows not working is a bad solder joint inside the window ecu. Drop the glovebox completely down, remove the card edge connector,grasp the circuit board with needle nose pliers and yank it straight backwards to remove, reflow solder joints and put it back in. Reconnect plug and test windows.
Common problem on DI's. Paypal your appreciation to dannyleebullseye@hotmail.com
Old Aug 13, 2012 | 11:54 AM
I suspect that we are both right, the tech calls any module a body control module; and the windows do have their own ECU, but it just does the windows. Cold solder joint in it will make things not work.
Mecevans
Aug 9, 2015 02:30 PM
remaximus
Oct 21, 2013 06:52 PM
nik
Feb 15, 2012 07:42 PM
djones70
Apr 4, 2008 08:53 AM
The Capstone
May 11, 2006 12:57 AM
